Author Topic: I need a carb sync - Anyone in North London?  (Read 17340 times)
Offline michtag
« on: August 11, 2020, 12:41:45 PM »
Hi guys,
I've been chasing gremlins (and possibly ghosts) on my 1977 CB550K3 ever since I got it 20 months ago. Done very little riding (almost none), lots of tinkering, got burnt by a mechanic that did some things right and some other he messed up completely, I cleaned the carbs several times, changed spark plugs and caps, air filter, manifold o-rings, new condensers.....basically everything I could think of that could cause my problems.
Aaaanyway, with 30 years of Vespa riding, I am a novice when it comes to Hondas. I have a great passion for mechanics and I believe I have done all I should have done so far (mostly a 3k tune-up) to a decent level, BUT, I have nobody to be able to check that for me, so I may be chasing my tail forever.
The bike starts fine, just a little choke, and idles ok, but as soon as it warms up (2 mins or less) the idle fluctuates, with no input from me, between 1000 and up to 3000 rpms. This is a great improvement to what it was as it used to shoot up to 5k and would hang in between gear shifts, which made it unridable.
The battery is fully charged....but then again, I am not riding this often at all and have recharged several times, so it may well be the battery itself giving me problems, but I need to eliminate other things before I think about replacing that.
The last 2 things I "believe" I need at this point are
-Timing set with strobe light (I have done the static, but assuming the advance mech. springs may be a bit weak only the strobe lamp will shed true light on this (sorry, this is a terrible "dad" joke....my kids would be ashamed)
- Carb sync: I have the necessary gauge tool and I have watched several videos on how to, however I have never done before and I don't have a proper space to do it (without annoying a few neighbours...)
My question to the audience:
Anyone in North London area (I am in N5) who could help me with these last 2 tasks? I have an old strobe light and the gauges set for the sync, but never really used them before and I would appreciate an expert and watchful eye from a more experienced member.
I tend not to trust my bike too much (it's probably all in my mind) and I am weary of getting stuck on the side of the road, but there are worst things in life and I will of course travel 10-20 miles to reach you.
I will also wear a facemask and keep social distancing, needless to say.
Anyone available around here?
Alternatively, anyone knows a good mechanic around here who would do it (and knows how to) without skinning me alive?
Michele
[Edit]
Went for a short ride today (4 miles, city roads) and I have a feeling the bike is not as sharp as it should be, it feels it can't get all the power out (and I am just opening the throttle in 1st, 2nd or 3rd) a bit like when you have something stuck in your throat and your voice's not clear.
So, re-checking points gaps and timing (will try using my strobe light) will be my priority this week.
Any other suggestions are welcome, as I said, I have no real term of reference in my experience....
« Last Edit: August 12, 2020, 04:23:47 PM by michtag »
-- I will fix it...or at least I will understand why I can't --
1977 Honda CB550K3
Re: I need a carb sync - Anyone in North London?
« Reply #1 on: August 12, 2020, 04:45:43 PM »
If you've not anything sorted in a while I'll go over it with you,  but on holiday for a couple of weeks unless we get covidded?  out of our family camping trip to Cornwall  :D
Can work with your kit to familiarize and build your knowledge.
Back about 29th August,  let us know after if you still want help.
Offline michtag
« Reply #2 on: August 12, 2020, 05:34:00 PM »
Thank you so much K2-K6!!!!
I'll see what I manage to do (or re-do) in the next couple of weeks and then get back to you on this. It would be great to have an expert check what I am doing :)
Michele
1977 Honda CB550K3
« Reply #3 on: August 12, 2020, 09:46:30 PM »
"[Edit]
Any other suggestions are welcome, as I said, I have no real term of reference in my experience...."
To help in the interim,  it's sounds possible from your above observations that you may have a  cylinder not firing.  The points each run two cylinders so if either is a problem you get both from that supply stopping and it's even hard to pull away,  so doubt if it's that.
More likely it could be just one.  If you start it from cold and run for about 20 seconds,  switch off and then feel each of the exhaust pipes youll tell if you've a cold one ( that will feel more like the "something stuck in your throat" you describe) if that's the case then ordinarily you're looking at a fault of the HT part of the system from coil through plug cap to plug itself as initial suspect.
Anyway,  post how you get on and shout if you wish to have help.
Offline paulbaker1954
« Reply #4 on: August 13, 2020, 07:55:22 AM »
Are you positive you don’t have an air leak between carbs and head. That would also cause similar problems. Try spraying carb cleaner around the joints when running. I had exactly the same tickover issues with revs suddenly rising and fixed it with new inlet rubbers. I also used jubilee clips (thin stainless ones) as opposed to the old Honda clips as even the replacement ones I got (not  aftermarket ) from DSS were no sealing well.
From the sound of it this is more likely the problem
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline michtag
« Reply #5 on: August 13, 2020, 12:54:29 PM »
Thanks K2-K6, all 4 are firing, I check by default every time I run the bike for 20 secs or so as I did have that problem in the past (but it was carb related).
1977 Honda CB550K3
Offline michtag
« Reply #6 on: August 13, 2020, 12:58:36 PM »
Thanks Paul, I have not really tried spraying carb cleaner because I have new inlet rubbers and new O-rings on the inlet manifolds, so I believe I have taken care of that possibility. I still use the old clips though, so I may as well give it a try. FYI, I will soon post a video of how erratically it idles today, just to give as much info as I can.
1977 Honda CB550K3
Offline michtag
« Reply #7 on: August 13, 2020, 01:25:39 PM »
Update of the day:
Just before thunderstorms hit (although it's still well sunny here) I decided to have a check at the timing.
-Points gaps were at 0.3mm and 0.35mm, so I made them both 0.3mm now.
-Static timing is spot-on for 1-4 and 2-3
I have tried using my strobe but the idling seems too unstable that I am not sure about anything, so I have not tried to adjust anything. I will try again just to see if I notice it being too far advanced at higher revs, but from first examination it does not look that way. It may be that it advances too soon though. I have tried in the past to use different spring combos in the advance mechanism but never really solved anything, so I reverted to the original setup (I was probably jumping the gun anyway).
Here's a video I shot today, just to give you an idea of what it sounds like when idling. Note that unless you see my hand on the throttle or idle screw, she's doing everything else by herself!
https://youtu.be/ESx_E8mv2vM
Carbs are standard PD46A with. standard jetting, This may not be ideal for the Delkevic 4 into 1 the PO put in, but it should not give problems when idling
As suggested above, I will try spraying carb cleaner on and around the inlet manifolds to check for air leaks there, but I have new manifods and o-rings so I doubt it will be that.
1977 Honda CB550K3
« Reply #8 on: August 13, 2020, 01:30:21 PM »
What spark plugs are you using?
Offline michtag
« Reply #9 on: August 13, 2020, 02:11:31 PM »
Just plain NGK DR7ES they are fairly new, maybe have 30 miles on them. I cleaned them from carbon deposit because the mechanic I trusted to solve my troubles actually made it incredibly rich (4th groove on et needle!!) and as a consequence exhaust and plugs just got covered in black soot. BTW, I moved the needles back to the 2nd groove...
Not sure I have a new set of plugs to try if any difference now, would that be worth it?
1977 Honda CB550K3
« Reply #10 on: August 13, 2020, 02:58:41 PM »
Remove the resisted plugs and fit non resisted (D7ES or D7EA) . You only need resisted plugs fitted if you have non resisted plug caps fitted. Too much resistance weakens the spark. I don't think it will solve your problems but having both plugs and caps fitted with resistors won't help.
The DR7ES were the standard fit with the metal, non resistor caps, which were changed at PDI usually (well, thrown in the bin as I understand it).
« Last Edit: August 13, 2020, 03:05:16 PM by Nurse Julie »
Offline michtag
« Reply #11 on: August 13, 2020, 03:29:19 PM »
A-ha! that is useful info indeed, I had not realised. Well it may not solve this problem, but it can't hurt and it is more correct. In fact from older pics I can see my bike came with D7EA, so I must have bought DR7ES just reading old specs around.
Thank you Nurse Julie!!
1977 Honda CB550K3
Offline Seabeowner
« Reply #12 on: August 13, 2020, 06:11:38 PM »
I have the original metal plug caps one of my 500s. They all measure 5-6k ohms. I've used resistor and non-resistor plugs and never had an issue. Original plug caps on my US 500K0 are 7.5k.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #13 on: August 13, 2020, 08:00:26 PM »
I don't see it as a fault either.  The general internet view is significantly skewed I feel with it usually resulting in a dead end argument of never the two should meet  :D
Granted you get a different effect,  particularly it appears to lengthen spark,  which is useful IF you can make advantage of the characteristic.
The theory that it generates less spark appears to be derived within magneto systems,  but used in error for coil based system.
It'll be interesting to see if there's any improvements by changing the plugs,  but think there's potential circumstances under which that would indicate another error.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #14 on: August 13, 2020, 08:17:22 PM »
Michele, a long shot, but is the petcock gauze clear. I had erratic fuel flow and cleaned it in vinegar and very gentle brush with an old toothbrush. Then a column of water from a tap would pass freely through it uninterrupted.
I find even when all clean, fuel often only manages to flow through one pipe at a time, so eg from empty, carbs 1&2 and 3&4 don’t both get full flow at the same time, and maybe a slight restriction could cause flow to fluctuate.
As I say very much a long shot, but quick and easy to check, and always good to know it’s ok.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
