Author Topic: need a seal part no  (Read 8444 times)
MIKE550/4
need a seal part no
« on: September 07, 2009, 10:31:52 AM »
difficult to pin this down in words,
 steve d  you dont happen to have parts list photo for the front spindle do you ,
 best i can explain is where the chrome cover sits speedo side , under that chrome cover there is part which splits into 2, round the part that pushes out is a rubber seal, it looks like a ver small rubber band
550 k3
cheers if you can help
MIKE550/4
Re: need a seal part no
« Reply #1 on: September 07, 2009, 10:56:48 AM »
nearest pic i could find , part 8, the middle section pushes out and there is a seal round the part that comes out, only gives part no for whole item, only need the seal ... anyone ?
http://www.motogrid.com/pages/parts/viewbybrand/parts.aspx
Offline matthewmosse
« Reply #2 on: September 07, 2009, 11:31:04 AM »
Silvers can normally find these bits over the phone without part numbers, might do the trick. Ps did you get the bearing retainer out in the end?
« Reply #3 on: September 07, 2009, 12:13:04 PM »
Don't know if this helps, but...
MIKE550/4
« Reply #4 on: September 07, 2009, 12:15:14 PM »
Yes its all stipped , have one side of bearing back in , had to chop it out in the end , still  got to do back wheel ,  big learning curve for me this but getting there
MIKE550/4
« Reply #5 on: September 07, 2009, 12:21:47 PM »
will see if its available seperately cheers
MIKE550/4
« Reply #6 on: September 07, 2009, 12:58:15 PM »
Well not available from ds, might have to make something
« Reply #7 on: September 07, 2009, 05:04:39 PM »
The only seal I know of is part of the speedo drive.
MIKE550/4
« Reply #8 on: September 07, 2009, 09:34:33 PM »
bryan on that part no  8 there is a section that pushes out, round that part there is like a band will try and get a pic up
MIKE550/4
« Reply #9 on: September 08, 2009, 10:24:10 AM »
can i get away with re using or adapt something else
« Reply #10 on: September 08, 2009, 10:58:34 AM »
I don't see why not - there's no oil pressure behind it is there?
MIKE550/4
« Reply #11 on: September 08, 2009, 12:03:11 PM »
that i am unsure of
« Reply #12 on: September 08, 2009, 01:34:03 PM »
That was a rhetorical question Mike...    ;D
There is no pressure - it's just a grease seal for the front wheel.
MIKE550/4
« Reply #13 on: September 08, 2009, 01:39:07 PM »
 :D
Oh right steve, will make something to get this sealed up , just got back to change bearings and then wheels can go back on
getting there slowly
« Reply #14 on: September 09, 2009, 07:02:21 AM »
That speedo drive plate is totaly different to ANYTHING i have seen before!! It ought to be one steel piece or how will it drive the gearbox?
