need a seal part no
Topic: need a seal part no (Read 8451 times)
MIKE550/4
need a seal part no
September 07, 2009, 10:31:52 AM »
difficult to pin this down in words,
steve d you dont happen to have parts list photo for the front spindle do you ,
best i can explain is where the chrome cover sits speedo side , under that chrome cover there is part which splits into 2, round the part that pushes out is a rubber seal, it looks like a ver small rubber band
550 k3
cheers if you can help
MIKE550/4
Re: need a seal part no
September 07, 2009, 10:56:48 AM »
nearest pic i could find , part 8, the middle section pushes out and there is a seal round the part that comes out, only gives part no for whole item, only need the seal ... anyone ?
http://www.motogrid.com/pages/parts/viewbybrand/parts.aspx
matthewmosse
September 07, 2009, 11:31:04 AM »
Silvers can normally find these bits over the phone without part numbers, might do the trick. Ps did you get the bearing retainer out in the end?
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
September 07, 2009, 12:13:04 PM »
Don't know if this helps, but...
MIKE550/4
September 07, 2009, 12:15:14 PM »
Yes its all stipped , have one side of bearing back in , had to chop it out in the end , still got to do back wheel , big learning curve for me this but getting there
MIKE550/4
September 07, 2009, 12:21:47 PM »
will see if its available seperately cheers
MIKE550/4
September 07, 2009, 12:58:15 PM »
Well not available from ds, might have to make something
September 07, 2009, 05:04:39 PM »
The only seal I know of is part of the speedo drive.
MIKE550/4
September 07, 2009, 09:34:33 PM »
bryan on that part no 8 there is a section that pushes out, round that part there is like a band will try and get a pic up
MIKE550/4
September 08, 2009, 10:24:10 AM »
can i get away with re using or adapt something else
SteveD CB500K0
Administrator
Reply #10 on:
September 08, 2009, 10:58:34 AM »
I don't see why not - there's no oil pressure behind it is there?
MIKE550/4
Reply #11 on:
September 08, 2009, 12:03:11 PM »
that i am unsure of
SteveD CB500K0
Administrator
Reply #12 on:
September 08, 2009, 01:34:03 PM »
That was a rhetorical question Mike...
There is no pressure - it's just a grease seal for the front wheel.
MIKE550/4
Reply #13 on:
September 08, 2009, 01:39:07 PM »
Oh right steve, will make something to get this sealed up , just got back to change bearings and then wheels can go back on
getting there slowly
Reply #14 on:
September 09, 2009, 07:02:21 AM »
That speedo drive plate is totaly different to ANYTHING i have seen before!! It ought to be one steel piece or how will it drive the gearbox?
need a seal part no
