Author Topic: What size & type of clips are best for my fuel hose ?  (Read 2953 times)
« on: September 01, 2020, 01:56:18 PM »
My hose arrived today its from Planet Silicone 9.4 mm o/d 5.4 mm i/d went to fit it and realised as the bike came without a fuel pipe on it I didn't have any clips in the box of oddments I was given all my existing clips are automotive and far too big.
What size actual clip do I need is it 8 or 9mm to get enough pinch on the pipe?
Is S.S. worth the extra cost whilst I am buying?
Offline Erny
  • CB750K7 CB550K1
Re: What size & type of clips are best for my fuel hose ?
« Reply #1 on: September 01, 2020, 03:07:27 PM »
If you talk about fuel hose between tank tap and carbs, I don't use any (hoses are 5.5mm id)
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #2 on: September 01, 2020, 03:44:01 PM »
Same here. The modern hose I got from DSS it so elastic it stays put.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #3 on: September 01, 2020, 04:01:17 PM »
Thanks both of you - I'm probably just thinking too automotive - there isn't much pressure as its just gravity !
It doesn't help that I didn't have the old ones to go by - that said all four of the fuel overflow pipes have small clips on them - not sure if that's original though.
Ted
Offline Erny
  • CB750K7 CB550K1
« Reply #4 on: September 01, 2020, 04:07:08 PM »
I still have clips on small overflow tubes too as I had them with bike from PO.
You can still buy clips in nearest Honda dealer btw..
Offline Skoti
« Reply #5 on: September 01, 2020, 05:28:22 PM »
Aftermarket Honda type fuel hose clips:-
https://www.louis.eu/artikel/hose-clips-10-pieces-different-sizes/10018004
I've used them and they work ok.
Skoti
1976 Honda CB750F1
