Author Topic: Front Axle query  (Read 4813 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Front Axle query
« on: September 27, 2020, 06:45:18 AM »
Hi,
Reassembling the front end of the K2 with a couple of questions.
(1) never particularly noticed in the past, but the axle is about 3mm short of flush with the axle holder. The axle is in the correct orientation (ie hex side by the disc) and looks normal wrt the various clearances. Notably though the 400F’s axle is flush in this respect. Comments? (the forks were removed off the bike)
(2) the fork seals have been replaced; and I note the ‘book says 225ml of oil to replace for the K2..... and other volumes for K3 blah blah. Q. The bike is nearly 50yo.... how can I tell what forks are on it... they may have been changed out in the past?
Ta.
S
Online Bryanj
Re: Front Axle query
« Reply #1 on: September 27, 2020, 07:33:58 AM »
Try rotating the fork tubes in the yokes and see if the gap varies indicating slightly bent tube, fairly common.
As to oil pick a quantity and make sure both are same thats more important than exact quantity
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #2 on: September 27, 2020, 09:22:36 AM »
From what I have read, if you have a back-up ring under the circlip, chances are you have early forks. Another external test is whether there is a bolt at the bottom holding the damper in. If no bolt, you have very early forks; I believe the bolt appeared at K0/K1.
The outside appearance of the lowers gives another clue:
If that doesn’t help, you can tell by the innards.
It says original because that was what in there when I dismantled them. Later contents:
When I replaced my springs with IKON progressive springs, this was the advice I was given by IKON rep:
As prior I suggest you remove the springs and fill with about 400cc oil, stroke the fork slowly to bleed, then measure the height of the oil from the top of the tube, with the fork collapsed. Looking for 140mm of space between the top of the fork tube to the top of the oil. Add or remove oil till you get that set evenly, then install the springs and cut spacers as needed to get a total of 25mm of preload on the springs. Measure preload by placing the fork cap on top of the spring and spacer, measure the distance between the top of the fork tube and the sealing surface of the fork cap. Do this measurement with the fork assembly fully extended.
[/i]
The preload bit may be specific to the springs, so take the above as a suggestion only.
I’d be interested to hear what others think of this, because after replacing the springs and shocks (IKON also) the bike developed a severe head-shake at about 35-35kph if I took one hand off the bars. This quickly settled and at higher speeds it was fine. I have yet, 20,000km later, to solve this problem, so any ideas welcome. I have just rebuilt the forks completely while replacing the seals, so here’s hoping 🤞
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: September 27, 2020, 01:10:06 PM »
...aah thanks Bryan; that makes a lot of sense; didn’t occur to me. (tho’ the stanchions  are new’ish / DSS pattern & I’d bloody hope true!)
Thanks too Sean; your info does indeed suggest my forks are K2. The forks are now buttoned up with the spec 225ml of W5; I’ll road test it before going the slightly more tech route you outline. (kinda want to see the back of the front end so-to-speak! 😂)
Cheers,
Simon.
Online Bryanj
« Reply #4 on: September 27, 2020, 02:05:51 PM »
I have seen bent yokes cause the same problem but that is rarer though as you say new tubes ought to be true!! I have never checked but i would think its possible that axles may vary. Cant be arsed to go through parts books at moment to check
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: September 27, 2020, 10:36:36 PM »
...the varying axle (length?) theory could hold water as the inner clearance seems minimal... ie I don’t reckon the wheel should be any nearer the fork tube?
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: September 28, 2020, 12:31:17 PM »
... any ‘750 owners elaborate on the fork tube to speedo hub clearance pls? Does mine look normal...
Ta.
Offline Andrew-S
« Reply #7 on: September 28, 2020, 01:05:31 PM »
Ta.
Here's my 11/70 K1 which is pretty original - hope these help:
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Online Bryanj
« Reply #8 on: September 28, 2020, 01:27:06 PM »
That gap looks a bit big from memory, i thought the speedo drive more or less touched the fork slider
Offline SeanFD
« Reply #9 on: September 28, 2020, 02:30:41 PM »
‘72 UK 750 K2.
Oh, forgot to add; I haven’t tightened the fender bracket bolts, so that slight gap may well disappear when I do.
« Last Edit: September 28, 2020, 02:32:19 PM by SeanFD »
« Reply #10 on: September 28, 2020, 02:53:53 PM »
Here's our 750 K2. All bolted up.
« Reply #11 on: September 28, 2020, 03:11:16 PM »
Check out my Z1 resto thread in 'Other Bikes', a suspiciously similar gap between fork and spacer on the front spindle turned out to be a bent bottom yoke, as predicted by Royhall.  8)
That said it was a lot worse than your gap.
« Reply #12 on: September 28, 2020, 03:12:33 PM »
Lobo , it is because you have your mudguard on pushing the forks out  ;)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #13 on: September 29, 2020, 12:26:11 AM »
Thanks all. Yea Trig, you’re a funny man 😂😂😂!
(PS - I want my original forks back 😂)
« Last Edit: September 29, 2020, 12:31:21 AM by Lobo »
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #14 on: September 29, 2020, 09:15:04 AM »
Sorted. With the front of the bike up and axle holders loosened I gained abouts a mm of Bryan’s ‘rotate the stanchions’ suggestion, and a further mm by simply pulling the slider against a spoke. (Minimal forefinger effort).
That leaves the third & last mm as speedo hub to fork slider clearance- can’t imagine it should be any less.
Thanks all.
PS - Andrew! You’re Avator looks spookily like mine! You been raiding my photo files? 😂
« Last Edit: September 29, 2020, 09:21:06 AM by Lobo »
