Author Topic: Swing Arm Insertion  (Read 4174 times)
Offline waffey
Swing Arm Insertion
« on: October 03, 2020, 03:08:27 PM »
Hi,
after getting stuff back from the plating company, I started to install my swing arm. I am struggling to get the swing arm with the caps on to fit, not sure if is the powder coating on the frame that will not allow it to be pushed through to line up with the bolt. Anyone else had this issue and if so how did you get round it? I'm think maybe a bottle jack or scissor jack inserted into the fram just to push it out a little. That should be ok?????
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Offline TrickyMicky
Re: Swing Arm Insertion
« Reply #1 on: October 03, 2020, 03:32:48 PM »
Not quite sure how to word this, but here goes. When I last removed my swinging arm, it was a long while before I replaced it and the memory bank failed for quite a while! I was at the rear of the bike and trying to push the bugger forwards into its correct location, NO CHANCE!!  After an eternity I remembered that you tip it slightly sideways, move it forwards so it's close to the back of the gearbox, get it nice and horizontal again, and then pull it BACKWARDS into the frame location. It's tight, but there again, it's meant to be. Have fun! Regards, Michael.
Offline waffey
« Reply #2 on: October 03, 2020, 04:12:07 PM »
Thanks TrickyMicky
i'll try that tomorrow
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #3 on: October 03, 2020, 04:19:04 PM »
If you had the swing arm powder coated as well the coating on the ends can hold the plastic thrusts, if you are using original parts, or the flanges on brass top hat bushes too far apart making the swing arm impossible to fit.
And yes coating inside the frame can have the same effect and both together is really difficult.
A scissor jack used carefully would work
Offline CB400JAY
« Reply #4 on: October 03, 2020, 05:27:04 PM »
I would remove any powder coating from the inside of the frame where the swingarm contacts it. Do not force it in.  Once installed torque the swingarm bolt and make sure the swingarm pivots easily.
« Last Edit: October 03, 2020, 05:28:37 PM by CB400JAY »
« Reply #5 on: October 03, 2020, 06:06:59 PM »
The swing arm will always pivot as long as the collar is the correct length as that should be pinched between the frame sides by the bolt
Offline Mag1
« Reply #6 on: October 03, 2020, 06:47:31 PM »
How thick is the powder coating?, when I was doing mine it should be a sung fit but not too hard to install. Remember that when torqued up it will pull together tight. If I remember when I did my bike I filed all the coating off and greased the cups and frame.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline Mag1
« Reply #7 on: October 03, 2020, 06:49:23 PM »
Sorry should have said I have 750, but should be same method
Honda CB750K7 1977
Yamaha XS750e 1977
Offline waffey
« Reply #8 on: October 03, 2020, 10:09:05 PM »
thank you all you're reply's, i'll attempt tomorrow by checking the amount of powder coating on the frame etc
ta
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
