Author Topic: rear wheel bearings  (Read 4600 times)
MIKE550/4
rear wheel bearings
« on: September 19, 2009, 05:52:21 PM »
well have the bearings out, heat and penetrating oil done the trick,
although is it right the rear spacer has came out out in two pieces, must stress it is not broke in two from what i can see,
can someone give me a guide on how to refit ie steps to rebuild and whether the spacer is ok to re use
thanks for a great site and i will put up some pics when i have a rolling shell
Re: rear wheel bearings
« Reply #1 on: September 20, 2009, 02:21:45 PM »
If the short spacer fits into one bearing inner race its ok to reuse the two, just straigten out the tricorn guides.
If it doesnt then a new one piece one is in order
