Author Topic: Tacho Gear... gearing  (Read 2113 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: October 08, 2020, 09:33:08 AM »
Hi,
To save me manually turning the crank 10 times and counting....has anyone got the definitive answer to the ratio of crank turns versus tacho gear turns?
(got the tacho apart, and figured I may as well spin it up (with a drill and an iPhone strobe) to set the needle back correctly. 😂. And yep, overly complicated but the bodies are drying and I love a good fiddle....)
Ta.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Tacho Gear... gearing
« Reply #1 on: October 12, 2020, 10:34:47 PM »
Ok, you’ve all been hanging on far too long for this one...
4 turns of the crank gives 1 turn on the Rev counter drive.
Whilst I’m at it, 1 turn of the front wheel gives 2.875 turns on the speedo drive.
« Reply #2 on: October 12, 2020, 10:46:46 PM »
🤣 🤣 🤣 🤣 If it keeps you brain ticking nicely Simon, these little things are worth doing.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #3 on: October 13, 2020, 09:19:42 AM »
That’s great; just the sort of info you can never find when you’re looking for it! 😂😂
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: October 13, 2020, 12:17:17 PM »
Yep Julie...all rather sad!
Hey Sean... I was born in Zambia (Kitwe).... there from ‘58-‘71. Did a bit of school in Zim / Marandellas (Peterhouse). You around then....?
Offline SeanFD
« Reply #5 on: October 13, 2020, 03:59:31 PM »
Nooo. I was just being born then!  ;D (‘57)
Been to Peterhouse on many occasions though; Ii bet it’s grown since your day. There is now a prep school and a Peterhouse Girls, across and up the road.
