Author Topic: Jeeze It's Getting Cold  (Read 11464 times)
Offline JonnyB
    • BatchScan
« on: October 09, 2020, 07:49:04 AM »
Still a few bikes on the roads in the morning,  but by-eck it's getting cold, nearly put the heated grips on, but trying to hold out until the clocks change.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
Re: Jeeze It's Getting Cold
« Reply #1 on: October 09, 2020, 08:28:41 AM »
I'm thinking of heated grips but it's only 5 miles to work.  I'd rather get a decent rear tyre.  This one's scary in the wet.
Offline cooleronthecoast
« Reply #2 on: October 09, 2020, 10:58:43 AM »
I use my heated grips a hell of a lot, even on summer days early in the mornings until the sun warms up and temperatures rise.  They just keep the chill off the digits.  Its not really the cold that keeps me from riding in the winter months, living in a rural area its all the crap on the roads.
Now where did I put that 10mm socket?
Offline JonnyB
    • BatchScan
« Reply #3 on: October 09, 2020, 12:32:42 PM »
My journey to work is only 7 miles all on main roads, with the exception of the one mile of the estate I live on where the council won't take responsibility and grit the roads.
John
« Reply #4 on: October 09, 2020, 12:42:40 PM »
This thread reminds me of my Dad back in the early 70's....'No, we are not putting the heating on until November, put another jumper on' 😁😁😁😁
Offline JonnyB
    • BatchScan
« Reply #5 on: October 09, 2020, 12:45:17 PM »
I like your Dad already, I've hidden the thermostat to stop the Missus putting the heating on :)
John
« Reply #6 on: October 09, 2020, 01:40:06 PM »
With a teacher wife, October half term was always the cutoff for heating and winter quilt etc.
Now she’s retired and at home all day it’s a completely different story!
Offline Moorey
« Reply #7 on: October 09, 2020, 01:51:30 PM »
I will say those dirt cheap Chinese heated grips work well. Especially the ones with two settings. They have lasted longer than some of the Oxford ones I have had. ;)
Offline JonnyB
    • BatchScan
« Reply #8 on: October 09, 2020, 01:55:27 PM »
I ride my K1200GT though the winter. came with factory fitted heated grips and a heated seat. Now that's an option worth having in the winter.
John
« Reply #9 on: October 09, 2020, 02:01:41 PM »
The heated seats on our Jeeps are so good that in the winter I have to switch them onto the low setting within 5 minutes as even with a coat between me and the leather seats I start to poach my bum! ;D
Offline Tomb
« Reply #10 on: October 09, 2020, 03:29:08 PM »
I put some £10 cheapo heated grips on my birds Kwak ER5 and they're way better than the Oxford ones I have.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline Moorey
« Reply #11 on: October 09, 2020, 03:49:17 PM »
£10 I meant the cheap ones.  ;D
Offline SumpMagnet
« Reply #12 on: October 09, 2020, 06:36:40 PM »
Sadly the heated grips I have on my Hornet are no longer made ( Datatool did them...with a slider built into the left grip for heat level, low voltage cutoff and a little falshing LED telling you the setting ) but I won't fit another set of Oxford grips.
Aside from the ever present fear of leaving the things on and draining the battery, the silly bendy bracket and lumpy control pad were awful to use. The brackets always fractured too.
I wired the first set up direct, and flattened the battery twice one winter....before I swapped to a relay setup through the headlamp wiring. As the bike had lights on permanently...but the lights went off when you hit the starter...I used that. Ignition off....lights go out...relay kills the power. Doesn't matter what you do with the switch.
Consdering the cost...would low voltage cutoff be that hard to include?
CB750F2 - in pieces
« Reply #13 on: October 09, 2020, 07:46:56 PM »
The latest Oxford grips do have a low voltage cut off.  I think they have done for a couple of years now.   Not expensive either, Check these out:
https://www.ebay.co.uk/itm/Oxford-Premium-Hot-Grips-Motorbike-Motorcycle-Scooter-Heated-Grips-SPORTS-OF692/264147930067?epid=1874471546&hash=item3d80718bd3:g:lqIAAOSw7MNcQiaj
« Last Edit: October 09, 2020, 07:50:45 PM by cooleronthecoast »
« Reply #14 on: October 10, 2020, 09:18:18 AM »
I'll hold off on the grips until next month.  Just bought a new tyre for the GPZ.  The back one is terrifying in the wet so it's got to go before I come off on a roundabout.
