Author Topic: Two quick questions ?  (Read 2828 times)
« on: October 21, 2020, 04:34:42 PM »
I have stripped the clutch case cover with Nitromores is this suitable for painting or do I need to get some 1200 grit and remove the dark patches?Cutch Cover by Macabe Thiele, on Flickr
I was given 2 free oil filters with the bike are EMGO any good they came with the two O rings?
Oil Filters by Macabe Thiele, on Flickr
Re: Two quick questions ?
« Reply #1 on: October 21, 2020, 05:08:23 PM »
I think you might need to key the metal with a light rub of 1200 or 1500 grit paper prior to painting.  If those marks are caused by salt staining the paint may flake after a while as the salt eats into the alloy and stays there. I get parts like this vapour blasted prior to painting (bead blasting though on brake calipers). I've never heard of Emico filters, for the sake of £5 I'd go for a genuine filter over a pattern part, too many horror stories of pattern filters breaking up in use and blocking the oilways  :'(.
« Reply #2 on: October 21, 2020, 05:53:15 PM »
Back in the 70's used rather a lot of Emgo filters and never had a problem, nowadays people have said that there electric parts are bad but if you pay half the price and they last half the time(which is my experience) can you really say they are terrible
« Reply #3 on: October 21, 2020, 06:16:50 PM »
I never use Nitromors these days .the formulation & affectiveness is cr*p compared with how it used to be .. when it was superb.
This is the closest I have found to the old Nitromors.... contains Methylene Chloride & Formic Acid (as in ant stings :) ) So you have to be careful with it. Typically £25 for  5 litres at autojumbles, including Newark were I got some last month (for £22)
« Reply #4 on: October 21, 2020, 09:15:07 PM »
Luckily I was given some old formula Nitromoors.
Offline Athame57
« Reply #5 on: October 21, 2020, 10:36:54 PM »
If you get these blemishes out and you can get up a good shine why paint your casings , fork lowers or rear brake cover? If I'm to be asked they look way better polished , and it isn't that hard keeping them that way!
1978 CB400F2 named Elen.
« Reply #6 on: October 22, 2020, 08:48:37 AM »
Very nice bike too much effort for me - I'll stick to paint on the engine.
Offline Athame57
« Reply #7 on: October 22, 2020, 01:16:51 PM »
It sounds like you aspire to be truly inseparable from your bike, I'd rather stick to the saddle myself though!!!   :o
