Author Topic: Next Question! 500 Sprocket Carrier  (Read 12380 times)
« on: October 23, 2020, 03:12:55 PM »
I'm trying to take the sprocket carrier out of the hub but its stuck fast. I've put the old sprocket on the carrier and tried to drift it out by using a bar through the spokes (not removed the old spokes/rim so I have a more stable platform to hold onto while trying to get carrier out). Bearing and holder removed already.
Am I missing something as it is struck fast - its not flexing as if its just stuck on the cush drive rubbers.
Online Bryanj
Re: Next Question! 500 Sprocket Carrier
« Reply #1 on: October 23, 2020, 04:11:31 PM »
You have unscrewed the LH thread retainer havent you?
« Reply #2 on: October 23, 2020, 06:06:20 PM »
Yep, thats out Bryan. Its solid with no 'bounce' if it was stuck on the rubber cush drive - its a metalic feeling through the bar as I shock the sprocket.
Online Bryanj
« Reply #3 on: October 23, 2020, 07:19:39 PM »
They can get incredibly stuck on the rubbers and also on the big O ring thats D shaped, dont damage that one i have run out of NOS ones
Offline Erny
  • CB750K7 CB550K1
« Reply #4 on: October 23, 2020, 08:24:40 PM »
I did not disassembly mine, but I've read that a lot of heat (propane) helps. There are also some videos on YT too I was told.
I tired, but gave up as it was not absolutely necessary
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #5 on: October 23, 2020, 09:11:35 PM »
I think it may stay in the hub!
« Reply #6 on: October 23, 2020, 09:26:26 PM »
It needs to come out to be greased. If not kept greased they do wear out and very hard to find a good one  ;)
« Reply #7 on: October 23, 2020, 09:51:27 PM »
I'll get the lump hammer out in the morning!
Offline Erny
  • CB750K7 CB550K1
« Reply #8 on: October 23, 2020, 09:56:49 PM »
Not sure I understand - grease what? That rubber dumper or bearings? If bearings are worn, yes you have to take it apart, but otherwise?
« Reply #9 on: October 23, 2020, 10:11:47 PM »
Bearings are out Erny - don't need to take sprocket carrier off for bearings, just the retainer (which came out reasonbly easily - suprisingly!)
Offline Erny
  • CB750K7 CB550K1
« Reply #10 on: October 23, 2020, 10:16:42 PM »
Exactly and that's why I'm wondering what to grease then?
« Reply #11 on: October 23, 2020, 10:18:10 PM »
Over to you Graham!
« Reply #12 on: October 23, 2020, 10:49:28 PM »
This part needs fresh grease on it all the time or it will get damaged  ;)
Offline Erny
  • CB750K7 CB550K1
« Reply #13 on: October 23, 2020, 11:19:27 PM »
Then I should take it apart during winter
Thanks for advice!
« Reply #14 on: October 23, 2020, 11:25:47 PM »
There's also a flip side to this if it's seized,  it will give a very hard time to the primary drive system inside the engine and particularly the chain.
Relates to your other thread about engine noise Erny.
