CB750
On going electrical issue.
3
Topic: On going electrical issue. (Read 8450 times)
Re: On going electrical issue.
Reply #30 on:
October 27, 2020, 07:50:00 PM »
Again possibly a bullet connector, is there power on black wire to bulb? If so try grounding the wire at the neutral switch, if light works its switch if not break in wire from bulb to switch
Johnny4428
Reply #31 on:
October 28, 2020, 07:43:04 AM »
Thanks Bryan, yes grounding out from switch activated light, so I will check wire from switch to light panel if it’s ok I guess it will be switch.
Johnny4428
Reply #32 on:
October 28, 2020, 08:44:23 AM »
Good continuity between switch wire and headlight connection, think must be the switch.
Reply #33 on:
October 28, 2020, 08:45:02 AM »
If grounding it at switch put light on the switch is duff
Johnny4428
Reply #34 on:
October 28, 2020, 11:10:36 AM »
Yes Bryan, I will take it out and see if it can be revived until I replace.
Johnny4428
Reply #35 on:
November 08, 2020, 07:11:52 PM »
Hi guys just studying some of the pics I took last week and noticed this, possible short and definitely can’t be correct position of this retainer.
3
CB750
