Author Topic: DS Pilot Light Case  (Read 2811 times)
DS Pilot Light Case
« on: November 01, 2020, 11:29:17 AM »
https://www.davidsilverspares.co.uk/CB400F-SUPER-SPORT-FOUR/part_82422/
A couple of weeks ago I received the above "High Quality Aftermarket Direct Replacement" from DS and I am disappointed in the Quality aspect - is it just me as it seems a very cheap looking casing?
As I never had a CB400/4 back in the day am wondering if I expected too much or has the old casing aged to make it appear different?
Offline robvangulik
  • Honda Fourever
Re: DS Pilot Light Case
« Reply #1 on: November 01, 2020, 04:35:11 PM »
Looks good to me, what did you expect?
Offline Athame57
« Reply #2 on: November 01, 2020, 04:38:18 PM »
Looks ok to me. Is it possible it is sitting in stark contrast to clocks and other things around it?
1978 CB400F2 named Elen.
« Reply #3 on: November 01, 2020, 04:55:28 PM »
I've not fitted it in position yet just unwrapped it and was underwhelmed with how thin & cheap it felt. It's a really bright shiny plastic case. Maybe it needs weathering in.
Offline kent400
« Reply #4 on: November 01, 2020, 08:03:32 PM »
It's a good plan to check the warning lamp lenses are secure on these replica covers. I bit on extra glue around the edges of the lenses is worthwhile.
« Reply #5 on: November 01, 2020, 10:53:41 PM »
What's the decal like on top, the OE one is a sort of pressed metal plate, I suspect that will be a decal on silver foil.
My old one has slightly raised silver metal surround around the individual warning lamps plus the outline of the whole unit. The DS one is not raised as you say it's just a foil transfer so it looks the same but lacks any depth of field.
Luckily the individual colored warning lamp lenses seem solid enough. Nothing like an OEM replica the description High Quality is in my view journalistic licence. At £19.99 it would be okay but for £58.80 in my view it very overpriced. I don't object to a high price if the quality is there. It is certainly making me re-think items such as handlebar switchgear - genuine only if needed methinks.
Offline mickwinf
« Reply #6 on: November 03, 2020, 01:22:08 PM »
I agree that often pattern parts although they may do the job well enough are of poorer quality and with a little more care could be perfect, so why dont they do that?
