Author Topic: BATTERY TERMINALS  (Read 3180 times)
Offline Gromitdog
BATTERY TERMINALS
« on: November 02, 2020, 08:30:37 PM »
Could any please shed some light on where it is possible to get the the original type & shape & open ends battery terminals. I can find angled closed end terminals on AES, The terminal I am trying to find are the shaped ones that come off the battery which are sort of shaped to fit around the frame and direct the battery lead off in a nice direction to suit battery and direction of the lead.
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Re: BATTERY TERMINALS
« Reply #1 on: November 02, 2020, 08:47:49 PM »
The battery terminal ends are usually closed ends Nigel.
Offline Gromitdog
« Reply #2 on: November 03, 2020, 08:04:55 AM »
Hi Julie & Graham
Thank you for the update that will explain why I cant find the older types then.
« Reply #3 on: November 03, 2020, 09:24:53 AM »
Hi Julie & Graham
These are the original ones Nigel. Graham un solders them from the old cables and solders them back on the new cables.
« Reply #4 on: November 03, 2020, 11:11:40 AM »
You can cut some out of brass if you're stuck.
Offline Gromitdog
« Reply #5 on: November 04, 2020, 07:48:17 AM »
Hi Julie & Graham
Yes I am going to have to do the same I recon so hopefully my 65W soldering iron is unto the job   :)
« Reply #6 on: November 04, 2020, 08:19:22 AM »
You will not be able to do it with a 65w iron. You need a blow touch  ;)
