Author Topic: 400/4 Battery Location question ?  (Read 4123 times)
« on: November 06, 2020, 08:03:53 PM »
The battery connections on my bike were as follows when I bought her- the positive cable is nearest the fuel tank, the earth cable is nearest the rear wheel. The battery that came with the bike has the positive terminal as in the photo.
The live terminal is very close to the air cleaner frame/box where it could easily short out - I have inserted a small rubber pad for safety to tery to push the terminal away.
is there something missing to prevent this or is it not the right battery or cable layout?
IMG_20201106_195027 by Teddy Bagshaw, on Flickr
« Last Edit: November 06, 2020, 09:02:26 PM by Macabethiele »
Re: 400/4 Battery Location question ?
« Reply #1 on: November 06, 2020, 08:07:46 PM »
Your battery, in effect, is round the wrong way Ted. The battery terminals should be nearest the frame. I will take a pic of mine in a while.
Edit... Your cables are also around the wrong way and the battery looks much too tall.
« Last Edit: November 06, 2020, 08:16:29 PM by Nurse Julie »
« Reply #2 on: November 06, 2020, 08:25:15 PM »
Probably the wrong battery came with the bike it was dry charged when I bought it still in the box. I suspect you are right it is too tall as if fitted with the terminals next to the frame they would hit the tube.
I need to know the correct battery type number as original - DS site photo shows type CB12A-A on the casing. I might get lucky and find its just all back to front - certainly my cable runs look weird. My battery is marked as a MF CB12A-A  p/n712121 its 161 Tall.
I can move the Negative cable easily but the Positive  one is quite short not sure where it runs across the frame from the solenoid assuming it is the right lead fitted?
I'm pretty sure the main wiring harness routing is wrong in places as it's clearly very tight in some places with excess in others.
« Last Edit: November 06, 2020, 11:09:42 PM by Macabethiele »
Offline smoothoperator
« Reply #3 on: November 07, 2020, 08:53:12 AM »
Here is my battery set up. There was no battery with the bike. I bought it from Tayna batteries.
https://photos.app.goo.gl/To4JZfUjvrRE9bNX6
Steve
2017 Triumph Bonneville T100
Offline cliff7
« Reply #4 on: November 07, 2020, 09:33:24 AM »
Similar set up. My battery is same height. [ Guests cannot view attachments ]
« Reply #5 on: November 07, 2020, 10:16:48 AM »
I've reversed my battery so it fits correctly. The earth strap looks as though it fits on the engine mount nut OK. The positive now reaches the starter solenoid was upside down after some loosening of terminals it's now as it should be. When I come to replace the wiring loom I have no faith in the existing routing so will be on the look out for photos of how it should be routed. Workshop manuals are a very limited sources of such information. Some serious searching is ahead of me - old posts here etc. I guess there isn't a market for rebuild manuals. I take my hat off for those that build a bike from a boxes of parts.
Offline Deano400
« Reply #6 on: November 07, 2020, 10:23:45 AM »
This may help.
« Reply #7 on: November 07, 2020, 12:52:25 PM »
That earth strap aint original anyway
« Reply #8 on: November 07, 2020, 03:15:27 PM »
Thanks everyone for the input.
That is much safer battery now fitted the right way around.
.Battery fitted correctly by Teddy Bagshaw, on Flickr
« Reply #9 on: November 07, 2020, 03:18:18 PM »
This may help.
Thanks Deano that's really helpful for when I rebuild after full strip down. What is the source of the page as neither of the manuals that came with my bike have similar pages ?
As I suspected my loom has not been replaced but definitely it has been taken off and refitted with quite a few errors.
« Last Edit: November 07, 2020, 03:31:19 PM by Macabethiele »
« Reply #10 on: November 07, 2020, 04:09:37 PM »
Ted. Its page 110 of the 350/400 Shop Manual. It's in Alkadind (bloody spell check 😠😠😠😠,) Alladins Cave to download if you need it.
« Last Edit: November 07, 2020, 04:13:12 PM by Nurse Julie »
« Reply #11 on: November 07, 2020, 05:40:54 PM »
Thanks NJ forgot about the Cave! 😄
« Reply #12 on: November 07, 2020, 06:16:38 PM »
Still wrong Julie.
Aladdin’s Cave.
« Reply #13 on: November 07, 2020, 06:29:35 PM »
Still wrong Julie.
Aladdin’s Cave.
Blimey. I'm sure this phone is trying to control my life 😁😁😁 I would turn spell check and predictive text off... If I knew how 🙄🙄🙄🙄
« Reply #14 on: November 07, 2020, 06:50:29 PM »
Big Brother wont allow that Julie!!!!
