CB350/400
CB 400/4 Front Disc need ideas for Cleaning up .
Topic: CB 400/4 Front Disc need ideas for Cleaning up . (Read 4806 times)
THUNDERDOWNUNDER
SOHC Member
November 07, 2020, 06:12:55 AM »
Lots of Dodgy ideas on YouTube so thought I would ask the experts . Help !
taysidedragon
Re: CB 400/4 Front Disc need ideas for Cleaning up .
November 07, 2020, 10:31:56 AM »
What's the problem with it? Rubbing with steel wool should clean the disc surface ok. Wipe after with white spirit, let it dry. Good to go.
McCabe-Thiele (Ted)
November 07, 2020, 11:43:39 AM »
On cars I used to spin the wheels (usually front wheel on RWD) whilst applying the brakes having previously fitted a Wet & Dry paper pad between disc & pad - usually 180 grit to break the glaze. The wife had the job of applying light pressure so when it ripped it was her fault. lol
Back in the 1970's when unsold new cars were stored in fields near the ports one manufacturer actually supplied an insert to clean off storage surface rust!
Wire wool is probably easier - I have also found that the sponge type scouring pads are quite good - not White ones they are too soft but the green ones - they will actually scratch windscreen glass.
Last Edit: November 07, 2020, 06:32:19 PM by Macabethiele
Link to my full restoration
THUNDERDOWNUNDER
SOHC Member
November 08, 2020, 08:03:01 AM »
I would just like them to look better there is minimal scoring and thought may be a clean up on a lathe might be the go but it says on the Disc MIN THK 6 MM and I only have about 7 MM THK now . So better not go down that path !.
Depth 6 MM
November 08, 2020, 08:23:04 AM »
And stainless is a real swine to turn cleanly
THUNDERDOWNUNDER
SOHC Member
November 08, 2020, 09:20:00 AM »
Some pics of the Job
amx1992
November 08, 2020, 09:30:26 AM »
Just skimmed mine, i like working with stainless, turns nicely. Would have been a lot easier if po hadnt drilled holes in it
My disk wasnt in great condition, but i only ended up having to take 0.2mm off per side
Last Edit: November 08, 2020, 09:33:59 AM by amx1992
Colonial-Clive (yindi)
Colonial_clive
SOHC Expert
November 08, 2020, 11:38:42 AM »
I used a flapper disk on the angle grinder and lightly passed it over mine, it took all the crud off and left no scoring.
Lightly being the key word here.
THUNDERDOWNUNDER
SOHC Member
November 09, 2020, 07:03:13 AM »
Thanks for the info Guys . Will keep you posted on progress !
THUNDERDOWNUNDER
SOHC Member
November 12, 2020, 08:30:47 AM »
News Update . Sleazed up a treat . Used wet and dry with a sprinkling of WD40 . Clean
as a whistle now !
CB350/400
