Author Topic: Motad Exhaust F1/2 on a K3  (Read 11019 times)
Offline fazer1k
« on: October 25, 2009, 11:29:11 PM »
Would a Motad 4/1 listed for a CB550 F1/2 fit straight onto a K3 ? If not, can it be easily made to fit ?!
Thanks,
Ian
Re: Motad Exhaust F1/2 on a K3
« Reply #1 on: October 26, 2009, 06:29:10 AM »
You will have to modify the silencer bracket/centre stand stop otherwise all fits ok
MIKE550/4
« Reply #2 on: October 26, 2009, 11:14:53 AM »
i am awaiting a reply on e bay for a motad exhaust with same question , i am after an exhaust for my k3 ,
is this the same exhaust you are looking at ? would be pointless to bid against each other
Offline daz
« Reply #3 on: October 26, 2009, 06:07:18 PM »
Hi Ian, i have a brand new motad for your bike,
Honda CB 550K0 1974,  Honda CB500X 2020
Offline fazer1k
« Reply #4 on: October 26, 2009, 11:28:47 PM »
If the seller is based in Hull then it probably is ? :)
Looks like there may be a a lot of interest, did you get a reply ?
Offline fazer1k
« Reply #5 on: October 26, 2009, 11:32:36 PM »
Offline fazer1k
« Reply #6 on: October 26, 2009, 11:33:23 PM »
Thanks Bryan.
MIKE550/4
« Reply #7 on: October 27, 2009, 10:14:53 AM »
yes mate hull ,
he does not know told me to get in contact with motad,
sure bryan will be right though, bracket will need a bit of modifying, 4 into 4 bracket i have would seem to be specific to the k3 exhausts
Offline fazer1k
« Reply #8 on: October 27, 2009, 02:23:13 PM »
yes mate hull ,
Feel free to bid, I'm going to look at alternatives....good luck with the auction !
« Reply #9 on: October 27, 2009, 02:42:10 PM »
Needs altering as the rear footrests, to which the bracket bolts, are in a different place. Last one i did took 5 mins but needed a welder
Offline daz
« Reply #10 on: October 27, 2009, 05:56:23 PM »
Hi Ian, my location is Portsmouth Hampshire, thanks Darren
Offline daz
« Reply #11 on: October 27, 2009, 07:07:23 PM »
motad for 550 f models has M55H stamped on silencer, for 500 & 550 k0, k1, k2  & k3 has M5H stamped on silencer
