Author Topic: Honda 400/4 camshaft design is it normal?  (Read 4588 times)
« on: November 19, 2020, 03:31:26 PM »
I was a little surprised to find that the camshaft does not have replaceable bearings as it appears to run directly in the alloy head & camshaft cover. Fortunately my bearing surfaces look good. If needed how do you repair the worn housings?
Re: Honda 400/4 camshaft design is it normal?
« Reply #1 on: November 19, 2020, 03:37:58 PM »
You get a replacement head and cam cover. There was a project bike in Cassic Bike magazine that had been modified to use shell bearings off a Villiers industria engine but an extremely tricky maching operation to fit them I imagine..
discussed here:
http://www.sohc.co.uk/index.php/topic,7175.0.html
« Last Edit: November 19, 2020, 03:47:34 PM by AshimotoK0 »
« Reply #2 on: November 19, 2020, 04:50:25 PM »
Wow that sounds expensive to buy a head & cam cover. On my old 850 A series engine you could get the block line bored and later bearings fitted.
« Reply #3 on: November 19, 2020, 04:53:12 PM »
Quite often the cam cover is OK and the scoring is only in the head. Agree pretty expensive to fix,  so rule no.1 ... change oil regularly. Worst model for this happening is the CB250/360G5 IMHO.
« Reply #4 on: November 19, 2020, 04:55:46 PM »
The cam cover bearing surfaces are usually fine. It's the cam chain pulling the cam downwards that causes the problem to the head.
« Reply #5 on: November 19, 2020, 07:56:56 PM »
Yeah I had thought about that plus the valve springs pushing back on the camshaft.
« Reply #6 on: November 19, 2020, 08:56:05 PM »
As long as oil and filter changed every 1500 miles they will last 100's of 1000 of miles
« Reply #7 on: November 19, 2020, 09:53:00 PM »
I converted a 750 cam carrier (different design to the 400 I know) in the late 80's -used shells on bottom and new caps that held lowere shells in place then line bored, I did work at BAE system though so had access to the right machinery
