Author Topic: Rear wheel bearings and the spacer  (Read 2035 times)
Offline ph0010421
« on: November 23, 2020, 02:33:44 PM »
Hello
Feels like a daft question, but I've got replacement sealed bearings for the rear wheel. Feels wrong to remove the seal just so I can clip in the spider thing to hold the spacer. Which got me thinking what the spacer does?
Both bearings press against a machined shoulder as far as I can see. I can loose-loctite the diameter reducer in position on the bigger bearing so that doesn't fall out next time I withdraw the axle.
All the best, Paul
72 CB350Four
76 CB550
89 Townmate T80
Re: Rear wheel bearings and the spacer
« Reply #1 on: November 23, 2020, 02:48:49 PM »
I take it you are referring to the shoulder which the outer bearing ring fits against. I definitely would prefer the bearings being supported in the centre, thats where the clamping pressure is applied.
« Reply #2 on: November 23, 2020, 02:52:00 PM »
The spider thing doesn't hold the bearing 🤔
« Reply #3 on: November 23, 2020, 03:16:53 PM »
The spacer gives the all up total clamping dimension for the non rotating components within the wheel design,  so stays still with the frame spindle etc.  If the spacer is wrong in dimension it'll either pinch the bearings and preload them if too short,  or allow the wheels to ultimately move sideways if too long.
So dimension is critical,  how it's held is as you speculate as convenient to prevent it dropping out of alignment when the spindle is removed.  I guess the original is just the cheapest and simplest they found to do it,  but the placement is ultimately controlled by the spindle going through there. Making location just convenience.
It doesn't really matter if there's no "inside" face seal on the bearings as nothing really gets in there anyway.
You'd probably swear at it if you couldn't get the spindle through, well I would anyway  :D depends then how confident you are in the loctite solution.  It is more shear prevention (two surfaces sliding past each other) rather than "glueing" in position two components, so not ideal in doing what you want.
Offline ph0010421
« Reply #4 on: November 23, 2020, 03:42:01 PM »
You've articulated my concern nicely. So the spacer is clamped tight between the two bearings inners? Drifting out the second bearing came out like a missile so I didn't see exactly how it was.
Thanks Johnny
72 CB350Four
76 CB550
89 Townmate T80
Offline ph0010421
« Reply #5 on: November 23, 2020, 03:47:34 PM »
Hello Nurse Julie. Thanks for the reply. Yes, I worded it badly. When I drifted out the second bearing, it came out like a bullet, so I missed it, but the spider 'retains' the spacer to the groove on the bearing inner, no? To assist with assembly, I guess.
72 CB350Four
76 CB550
89 Townmate T80
« Reply #6 on: November 23, 2020, 04:05:57 PM »
Nope it located the spacer to the wheel macined bore but frequently gets distorted to a smaller diameter when removing bearings and needs the "legs" straigthening
Offline ph0010421
« Reply #7 on: November 23, 2020, 04:58:41 PM »
You the man. They came out looking like they'd been 10 rounds with Mike Tyson. I see exactly what you mean. Thanks pal
72 CB350Four
76 CB550
89 Townmate T80
