Author Topic: Crankcase disaster.  (Read 5155 times)
Offline SumpMagnet
Re: Crankcase disaster.
« Reply #15 on: January 29, 2021, 08:45:37 PM »
looks better inside than I thought it would do.
CB750F2 - in pieces
« Reply #16 on: January 29, 2021, 08:48:05 PM »
Good job so far!
Offline Seamus
« Reply #17 on: January 30, 2021, 08:54:33 AM »
Good luck with the repair, At least you know its possible.
Had similar with a K1 750, working on the motor and found a load of epoxy resin around the front of the sprocket. Damage where the chain had popped in for a visit. I was very fortunate as a mate had a bit of Kawasaki case that could be made to fit and had it welded up by an FIA approved aircraft welded. Only cost me a case of beer too.
« Reply #18 on: January 30, 2021, 11:06:04 AM »
Yes very annoying to discover the damage. I need to speak to a “metal smith” now and arrange repair. If the worst comes to the worst I know where to source replacement cases but would like to have these repaired.
« Reply #19 on: January 30, 2021, 01:38:20 PM »
If you are going for a weld repair, make sure the gear box is in place as, some of the cogs are very close to the case  ;)
« Reply #20 on: January 30, 2021, 03:11:28 PM »
Crankshaft looks good within spec. Centre bearing shell looks iffy!
« Reply #21 on: January 30, 2021, 05:31:40 PM »
Can't believe your going to weld that. Plenty of good K3 cases out there.
« Reply #22 on: January 30, 2021, 09:47:04 PM »
I hear you Roy! That is just the kind of comments I need to ensure I do the right thing. Cheers.
