Author Topic: Finally retired and building my project bike  (Read 46162 times)
Re: Finally retired and building my project bike
« Reply #45 on: July 12, 2023, 06:06:09 PM »
My 400 & 500 have the nylon type ring on the one static pad back.
I think Grahame is talking about the piston to pad contact being convex or concave.
Are you sure that is the correct fitment?
I understand it fits between piston and moving pad
« Reply #46 on: July 12, 2023, 06:57:33 PM »
TBH I can't remember now where that plastic washer went it's over a year ago now - my manual does not even show it as a part. I have it in my head that if it was on the static side otherwise it would sit inside the piston & serve no purpose.
There might have been a leaflet in the pad box someone here will have the right answer?
« Reply #47 on: July 12, 2023, 07:18:59 PM »
Goes on the back of the moving pad.
« Reply #48 on: July 12, 2023, 07:22:21 PM »
That makes sense in terms of anti-squeal function.
Updated:- A nagging doubt made me check my 500 front calliper - the nylon type washer can only  fit on the piston side as its a different shaped pad back to the fixed side.
« Last Edit: July 12, 2023, 07:54:21 PM by McCabe-Thiele (Ted) »
Offline gamma
« Reply #49 on: July 13, 2023, 06:17:50 PM »
Battery is in and not leaking as of yet.
Now working on fitting front indicators to the fairing, making brackets to fibreglass inside fairing
Offline gamma
« Reply #50 on: July 16, 2023, 07:39:51 PM »
Indicators done.
Getting closer to starting the engine.  I’ve put a very small squirt of diesel and 2 stroke oil in the bores and turned the motor on the starter. Oil light went out after about three bursts.
Offline gamma
« Reply #51 on: February 17, 2025, 11:02:15 PM »
After getting the bike running and balancing the carbs and fitting the unpainted fairing and seat just over a year ago. I’ve been busy with other projects and family stuff, but now I have been looking at trying to get this bike registered in Spain.
As it was built from parts from a scrapyard in Saudi Arabia, I have no paperwork.  And after speaking to various people here in Spain, it would seem that the best way forward is to get a UK Frame and V5, and to swap everything over onto the donor frame, then import the bike officially as a cafe racer from the UK.
Getting a Spanish donor frame with paperwork is difficult, I have tried, and then I would have to jump through many hoops to register all the changes from standard.
So if anyone on the forum has or knows of someone willing to sell a CB750 F1 frame and V5.
Please let me know, thank you
Offline Sifu
« Reply #52 on: February 18, 2025, 02:39:33 AM »
Very nice bike mate
« Reply #53 on: February 18, 2025, 03:26:35 AM »
There is a firm in Holland I think selling a wet sump conversion kit for the 750, means you can get rid of the oil tank from under the seat area. Just in case that idea appeals to you. Kit is called Sump Thing and appears to be very well made and good comments coming out of the USA about how it performs.
Offline gamma
« Reply #54 on: February 18, 2025, 04:34:48 PM »
Thank you Sifu and Oddjob😃
