Author Topic: Side stand CB550k 1977  (Read 11403 times)
Offline Wildshed21
« on: February 15, 2021, 07:59:44 PM »
My side stand hits the exhaust when up to the point where it’s left quite a big dent, the exhausts are the originals. I presume it shouldn’t touch the exhausts at all, Has anyone got a photo of theirs they could post please or ideas how to stop it. Previous owner seemed happy to live with it but the price of these exhausts I’d rather stop it before putting a hole in it
Re: Side stand CB550k 1977
« Reply #1 on: February 15, 2021, 08:03:27 PM »
There should be a rubber stopper on the exhaust part number  9501161000  ;)
Offline Wildshed21
« Reply #2 on: February 15, 2021, 08:10:09 PM »
Thanks but that’s for the centre stand which is is already on my exhaust so that’s fine it the side stand that’s bangs against the exhaust
« Reply #3 on: February 15, 2021, 08:52:43 PM »
Either the frame mount is bent or worn, which is very common, or the exhaust isn't fitted correctly, or the side stand is bent (also very common) or the wrong one for that model (and you've guessed it, also very common 😊)
Offline Wildshed21
« Reply #4 on: February 15, 2021, 08:55:56 PM »
Thanks Julie I was kind of thinking along the lines it might not be the correct stand as I’ve come across a couple of things that don’t seem right, doesn’t seem bent. Should it just about touch exhaust or clear it by a good amount ?
« Reply #5 on: February 15, 2021, 08:57:50 PM »
Not sure about the clearance but it certainly shouldn't touch.
Offline Wildshed21
« Reply #6 on: February 15, 2021, 08:58:36 PM »
« Reply #7 on: February 15, 2021, 10:34:18 PM »
If you post a side view pic of your bike, someone with a K3 will be able to advise on clearance.
Offline davidrsmith
« Reply #8 on: February 16, 2021, 04:38:29 PM »
I have just checked my K3 and my side stand is also touching the exhaust pipe when it is in the parked position. To be fair I very use the side stand, when I tried the side stand with the bike on the centre stand it appears there is a bit of lateral movement around the bolt which probably means that the bolt hole in the frame is worn. I may disassemble it this weekend and have a look.
Dave
Offline Wildshed21
« Reply #9 on: February 16, 2021, 05:19:22 PM »
Offline Wildshed21
« Reply #10 on: February 16, 2021, 05:24:18 PM »
Dave
Thanks for reply Dave, my side stand when in up position touches and if the exhaust wasn’t there it would raise even higher, something can’t be right, I’ve had exhaust off and back on again and it’s in correct position and the stand or mounting bracket doesn’t look damaged, but when riding it going to constantly bang and rub damaging exhaust even more
Offline Wildshed21
« Reply #11 on: February 16, 2021, 05:27:00 PM »
Offline 3scs
« Reply #12 on: February 16, 2021, 10:01:34 PM »
I’ve got no exhaust on my k3 at the moment but took this pic maybe you can check yours to see if it’s similar or if the stand is worn and allowing it to go too high
Offline Wildshed21
« Reply #13 on: February 16, 2021, 10:07:47 PM »
That’s brilliant thank you for taking the time to do that very much appreciated
« Reply #14 on: February 17, 2021, 07:39:56 AM »
Two types of side stands fitted to the K and F2, (with and without the rubber) depends on the country  ;)
Looks like  the stop on the frame is worn. A little weld will solve it .
