Author Topic: CMSL 500 Exhausts  (Read 3251 times)
CMSL 500 Exhausts
« on: March 10, 2021, 09:02:50 PM »
Just fitted the replica 323 exhausts I got from CMSL last year (bike nearly done now!) and fit was generally good except for centre stand stop bracket on the lower exhaust is about 20mm too rearward - stand just about sits on the edge of the rubber stop (if you let the stand flick up, it pushes past rubber and clanks into the exhaust). I think I will have to make a plate to put the rubber on and screw to the exhaust bracket.
Anyone else experienced this issue?
« Last Edit: March 11, 2021, 04:28:02 PM by philward »
Offline Steris
Re: CMSL 500 Exhausts
« Reply #1 on: March 14, 2021, 09:48:12 PM »
Yep, I had to do just that, my stand missed the stop completely.
Offline Honda Al
« Reply #2 on: March 15, 2021, 04:32:51 PM »
Same. Made a small plate to bring it back towards the front of the bike.
Offline paulbaker1954
« Reply #3 on: March 24, 2021, 08:47:05 AM »
I had exactly same issue, just made a small extension plate if I remember
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
« Reply #4 on: March 24, 2021, 06:10:01 PM »
« Reply #5 on: March 24, 2021, 09:52:05 PM »
Well not great that, anyone contacted CMS and told them? maybe they'll replace all the No3 cylinder pipes  ;D ;D
I'll probably make a bracket if mine does it but I'm thinking of using the main stand clamp bolts instead of the exhaust.
It's quite a way out. Just made one tonight out of stainless - you need to put a 90 degree 2mm lip (along the front to back length off the plate) to strengthen the bracket (20mm x 60mm ish plate really) - to stop it flexing when the stand hits the rubber
