Author Topic: Cb 550 ss spain  (Read 72386 times)
Offline murdock
Re: Cb 550 ss spain
« Reply #135 on: April 21, 2021, 09:48:42 PM »
Hello, while I wait for the pistons I bought in Japan to arrive I keep disarming and cleaning parts
But I stopped when trying to remove the rotor,the central screw is very hard and I think then you need an extractor, there is some trick to remove this ?
Re: Cb 550 ss spain
« Reply #136 on: April 22, 2021, 12:54:45 AM »
Easiest way to remove rotor bolt is an impact wrench either air or electric, yes there is a special tool to remove rotor it looks like a bolt that screws into rotor after holding bolt is out. DO NOT USE A 3 LEGGED PULLER
Offline eight0
Re: Cb 550 ss spain
« Reply #137 on: April 22, 2021, 08:08:27 AM »
I bought an M16 1.5 bolt from this seller. Worked perfectly.
https://www.ebay.co.uk/itm/291185866163
Offline murdock
Re: Cb 550 ss spain
« Reply #138 on: April 22, 2021, 06:21:52 PM »
Thank you very much for the tip !!!
You saved me a lot of time
The screw was very hard
Offline murdock
Re: Cb 550 ss spain
« Reply #139 on: April 22, 2021, 06:58:08 PM »
Sorry to abuse your wisdom, but does anyone know if there is an oil pump seal kit for sale?
Re: Cb 550 ss spain
« Reply #140 on: April 22, 2021, 07:41:02 PM »
The 3 O rings to crankcase should come in a complete gasket kit and the cover O ring Honda never sold as a spare but if you get a 46x2 O ring which is a Goldwing part it works
Offline murdock
Re: Cb 550 ss spain
« Reply #141 on: April 23, 2021, 08:48:50 AM »
Unfortunately my seals kit does not have them, the pump I do not plan to open it, that will be the 46, only would be the ducts and the one that seals the body to the housing, then try to measure it, but measures more than 50 mm x 3mm small I think 14
Re: Cb 550 ss spain
« Reply #142 on: April 23, 2021, 11:37:28 AM »
They do not come in the SEAL  kit they come in the GASKET kit
Offline murdock
Re: Cb 550 ss spain
« Reply #143 on: April 23, 2021, 02:45:05 PM »
My kit is not complete, I have taken measurements, 14x 3 mm and 53 x 3 mm I think it would work well, the 46 mm will be the inside, but I will not open the pump.
I will buy them loose for a few cents.
Offline murdock
Re: Cb 550 ss spain
« Reply #144 on: April 23, 2021, 10:48:17 PM »
I have opened the engine, everything seems fine, but I have found some wear or rubbing on the central selector fork, I don't know what gear it engages, the gearing looks fine, tomorrow I will check it in a better light.
Those are the numbers I was supposed to find right?
Offline murdock
Re: Cb 550 ss spain
« Reply #145 on: April 23, 2021, 10:54:28 PM »
The gear
Re: Cb 550 ss spain
« Reply #146 on: April 24, 2021, 06:44:49 AM »
I can supply oil pump kits in Viton . PM me for a members discount  >>> https://www.ebay.co.uk/itm/164714270515?hash=item2659bc4f33:g:UO0AAOSwYc5fvRQ4
Offline murdock
Re: Cb 550 ss spain
« Reply #147 on: April 24, 2021, 03:13:54 PM »
It's better to be clever than to buy more tools,
I don't know if I should worry about the shift fork, I'd just give it a little sanding and that's it, but you're the experts.
The bearings look good too. I have plastigauge ..... I don't know what to do , I change the chains and rubbers ,Seals and seal again ?
Offline murdock
Re: Cb 550 ss spain
« Reply #148 on: April 24, 2021, 03:19:25 PM »
Chain friction was negligible
Re: Cb 550 ss spain
« Reply #149 on: April 24, 2021, 05:09:01 PM »
I would replace the fork, with that wear it is probably bent the 550 primary chain does not hit as much as the 500 presumably the casting is different, still worth replacing chain and dampers
