Author Topic: Rear Brake Return Spring Location  (Read 3792 times)
Offline waffey
« on: March 15, 2021, 01:48:57 PM »
Hi,
i did look at some of the older post reference the rear brake return spring.
I'm sure mine is wrong as the spring does not have any tension. Please take a look at the pictures and tell me where i have gone wrong!
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Re: Rear Brake Return Spring Location
« Reply #1 on: March 15, 2021, 02:29:14 PM »
The long tail of the spring fits around the down tube of the frame. Here is mine, the free end on mine has a bit of rubber tube on it to stop it damaging the frame. Hope this helps. I can try and take another pic from a different angle if it helps.
« Last Edit: March 15, 2021, 02:31:10 PM by Nurse Julie »
Offline waffey
« Reply #2 on: March 15, 2021, 04:03:18 PM »
Nurse Julie,
can you get a picture where the small end of the spring sits on the inside of the frame? Thats the bit that is confusing me.
thanks for the other picture, i saw that in another thread
ta
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #3 on: March 15, 2021, 04:42:46 PM »
Nurse Julie,
ta
I'm trying desperately to get a pic for you, problem is the bike is at floor level and I don't have a ramp free to lift it up to get a pic. Has anyone else got their 400 in a raised position to take a photo please?
Offline waffey
« Reply #4 on: March 15, 2021, 05:37:39 PM »
O'm thinking the green spring piece highlighted should go where the red line is?
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #5 on: March 15, 2021, 05:53:24 PM »
Yes, I've just had a rummage and I can feel the other tale end going around a bit of tube. If it still doesn't work, I'll try harder tomorrow to take a better pic for you.
Offline waffey
« Reply #6 on: March 21, 2021, 09:03:09 PM »
Hi, still struggling with this damn spring. Any pictures of where ther inside spring locates pleaseeeeeeeeeeeeeeee...
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline waffey
« Reply #7 on: March 22, 2021, 09:20:03 AM »
OddJob,
I dont have any tension on the spring, thats my issue i believe. I get the tension when the pedal is pressed but when it returns the pedal is floppy as with the spring. Just thinking.........Do i need the footrest installed for it all to work properly, ie the peday return is stopped by the foot rest......i think this could be a Doh moment?
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #8 on: March 22, 2021, 10:00:56 AM »
OddJob,
Yes. The footrest bracket has an adjustable bolt on it that acts as a stop for the brake pedal.
