Author Topic: Rub N Buff  (Read 21709 times)
Re: Rub N Buff
« Reply #15 on: March 25, 2021, 06:36:47 AM »
"It will also be a mystery to them why everybody is suddenly buying the same colour."
That's gonna screw up their stocking rate if they've got it on automatic replenishment setting  :) two weeks time and a whole pallet will turn up at their address  ;D
Re: Rub N Buff
« Reply #16 on: March 25, 2021, 08:05:14 AM »
Extending the experience of longevity for carnuaba wax in this product, something like this also looks attractive for chrome finished parts of these bikes
 https://www.amazon.co.uk/Mothers-Brazilian-Carnauba-Cleaner-California/dp/B0002U1TVW/ref=asc_df_B0002U1TVW/?tag=googshopuk-21&linkCode=df0&hvadid=309775958298&hvpos=&hvnetw=g&hvrand=15506001129147191001&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9045909&hvtargid=pla-421986683506&psc=1&th=1&psc=1
With many chrome surface finishes being slightly porous (seen in spotty corrosion propagating marks) the wax would appear to be have good potential here too.
Re: Rub N Buff
« Reply #17 on: March 25, 2021, 08:09:07 AM »
There's going to be a run on Mothers 05500 now. I think I will buy a pallet of some product and put on here that its fantastic and watch the cash roll in.  ;D ;D
Re: Rub N Buff
« Reply #18 on: March 25, 2021, 09:45:41 AM »
Brilliant post this Ian .passing/sharing  on hints/advice tips and tricks is what these forums are all about..IMHO . .
Re: Rub N Buff
« Reply #19 on: March 25, 2021, 10:08:47 AM »
When I saw Mother's Brazilian I thought we were going somewhere else! 😂
Offline Orcade-Ian
    • Older Vehicle Web
Re: Rub N Buff
« Reply #20 on: March 25, 2021, 10:36:42 AM »
She told you to stop looking at those sites!
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: Rub N Buff
« Reply #21 on: March 25, 2021, 11:11:43 AM »
Yep, a steamy night out down the old Rub-n-Buff with some crucial Brazilian wax going down, brings a whole different focus to it  ;D
Re: Rub N Buff
« Reply #22 on: March 25, 2021, 04:10:06 PM »
Very intrigued to see the results from this rubbing and buffing. My only concern is how durable the finish is going to be - only way to tell is to try it. Let us know the collective feedback as you all progressively rub and buff...
Re: Rub N Buff
« Reply #23 on: March 27, 2021, 01:28:53 AM »
Arrived Friday .... that was quick delivery ! Interestingly ...  it was shipped as  contents 'nail varnish'. Will report back when I have 'had a go' on my CD175A sloper carb.
« Last Edit: March 27, 2021, 11:36:37 AM by AshimotoK0 »
Offline Orcade-Ian
    • Older Vehicle Web
Re: Rub N Buff
« Reply #24 on: March 27, 2021, 07:51:08 AM »
I understand James' concern about the durability of the finish but friend Leslie has been using this for some time now and I have seen his BM regularly but never thought to ask why it looked so good as all of his bikes are pristine.
I'm getting close to finishing this spare set of carbs and will post a pic when they are done but very impressed so far.
When these bikes were new, the carbs had no protective coating at all - how long did that last if left out in the elements?
Being cast, the grain boundaries in the metal allow the ingress of moisture into the first layers of molecules allowing the oxides to form.  Hopefully (!) the very thin layer of carnauba wax should form a barrier to this oxidation and the silver tint is really perhaps just 'bullshit in a tube'
I'm sure Ash - with his background will have thoughts on this.  I'm too old now to do a head to head test with a new carb untreated, one with carnauba wax applied with a toothbrush and one with Rub N Buff, all left out in the Orkney salt spray cabinet!
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
Re: Rub N Buff
« Reply #25 on: March 27, 2021, 10:02:40 AM »
Arrived Friday .... that was quick delivery ! Interestingly ...  it was shipped as  cnents 'nail varnish'. Will report back when I have 'had a go' on my CD175A sloper carb.
Seems most like lipstick in product match,  but with addition of turpentine.
A bit of "lippy" for your carbs sir  ;D
Re: Rub N Buff
« Reply #26 on: March 27, 2021, 12:03:21 PM »
Sadly, I don't think anything will restore that lovely iridescent finish you had on Keihin carbs originally James.
Offline mickwinf
Re: Rub N Buff
« Reply #27 on: March 27, 2021, 04:00:25 PM »
ok so i too ordered some, and it arrived today. I had a little play and experimented on a few items. This is now my new favorite product! First i tried it on an old carb body, used a tiny amount and rubbed it in. For the awkward corners i used an old paintbrush and it covered well and looks good, maybe even a bit too blingy but does what it says on the tin (tube!) also tried on some alloy parts, a caliper and bracket and a engine cover, again decent result even though i did not prepare the surface first. I then had another idea, on my kickstart and my brake lever there were some rusty marks where they rubbed together so i used the rub and buff, and found that it disguised the marks very well, and if you keep buffing it does shine the metal too. So i thought i will try a really rusty item, and found a chrome chain guard which is very rusty. I gave it a quick rub with wire wool first then with rub and buff. Obviously will not get rid of rust but did improve a lot. I think i may order some more colours and try on other things, all in all i recommend the product.
Offline mickwinf
Re: Rub N Buff
« Reply #28 on: March 27, 2021, 04:05:00 PM »
more pics
Offline mickwinf
Re: Rub N Buff
« Reply #29 on: March 27, 2021, 04:12:02 PM »
more, last pic shows a rear light base, the rh half has been treated and you can see it covers the small line of rust in the corner.
