Author Topic: Boot plug for intake manifold  (Read 7031 times)
Offline thomaspigeon
Re: Boot plug for intake manifold
« Reply #15 on: May 07, 2021, 09:30:35 AM »
Haha No problem Bryan, I found it. It’ll take a month to arrive though. Do you know the bandwidth of yours?
I found some 9mm (which is 3mm less than mine), is it narrow enough?
Also I found some cb550 inlet manifold in Germany for £40, worse the shot? I guess I’ll have to change the O-ring straight away. Find the links below. Cheers
https://www.ebay.co.uk/itm/253627467056
https://www.ebay.co.uk/itm/373513175775
« Reply #16 on: May 07, 2021, 10:15:23 AM »
O rings are same as tappet caps so readily available, if the rubbers are soft enough to use those are wrth a shot i will measure the clips i got seem to remember 8 or 9mm, you will need to cut off lots of extra when you put them on
Offline mickwinf
« Reply #17 on: May 07, 2021, 07:01:23 PM »
if you have not ordered the maniolds i have a pair of the correct ones, £25 pair plus post
« Reply #18 on: May 08, 2021, 12:34:01 AM »
@oddjob, jubilee clips ordered. A bit expensive but if that does the job I’ll be happy. Thanks for the tip.
« Reply #19 on: May 08, 2021, 12:54:27 PM »
I have PM’d you about it. Thanks
Offline mickwinf
« Reply #20 on: May 08, 2021, 01:57:08 PM »
hi Tom no message received yet
« Reply #21 on: May 08, 2021, 03:24:17 PM »
I just sent you one now. I’m not really good with that technology  ::)
