Author Topic: CB400 4 rebuild Where do I start  (Read 9375 times)
Offline stuartb
    • My Website, buy as many as you like
« on: January 18, 2010, 01:07:25 AM »
Hi, I am in process of starting rebuild on a 1978 400/4..its in poor order cosmetically, but otherwise ran fine till about 5 years ago, hasn't turned a wheel since..  I expect all the usual probs.  However, where do I start...  Do I pull apart, or try and get it running and assess whats required.  I rebuilt a CG125 around 25 years ago and have a mech/eng back ground so pretty handy with the tools..
Any advice would be great.
Thanks  Stuart
02 Blade, Blue and White..  Grotty CB 400/4 and a Grotty 1980 wing
Re: CB400 4 rebuild Where do I start
« Reply #1 on: January 18, 2010, 05:29:32 AM »
Get it running and maybe MOT'd first then start tydying up
« Reply #2 on: January 18, 2010, 07:26:46 AM »
I'm with Bryan.
Get it running, sort the brakes etc, MOT and ride it around for a while (doesn't matter how ratty it looks).
When (if?) you decide it's the bike for you, then set off on the refurb route (expect to spend
Offline matthewmosse
« Reply #3 on: January 18, 2010, 08:04:44 AM »
I'd also go with getting it running, that gives you the confidence to know what needs attention so you don't either refurbish something that's dead - frustrating, or refurbish/replace something that was fine anyway - expensive.
« Reply #4 on: January 18, 2010, 01:24:15 PM »
I would also go down the get it running route at least then you will know what it is that you have.
Den
Offline stuartb
« Reply #5 on: January 20, 2010, 09:39:34 PM »
Excellent guys TYVM...Ill keep you all informed...Do you know of anyone who is selling good body parts  tank, panels etc
Stuart
Offline UK Pete
« Reply #6 on: January 20, 2010, 10:12:54 PM »
If you do start taking it apart get as many photos as you can. they always come in usefull plus every one loves to see progress in pictures on the forums, i would suggest before you go too far cost up the bits you think you are going to need, i recently started a rebuild/ restoration of a 750, and it stands me in at least 3 times what i wanted to spend already.
Pete
Offline stuartb
« Reply #7 on: January 21, 2010, 11:18:03 PM »
Sound advice again pete, thanks for that.
Stuart
