Author Topic: Cb550 air filter  (Read 3978 times)
Offline 550turnip
Cb550 air filter
« on: May 08, 2021, 12:33:27 PM »
Hi
Air filters seem to be a bit thin on the ground for a cb550k0, is the cb550f the same filter but a different part number..my research seems to suggest so !
am I missing some other parts As well, I think should be air filter retaking spring and a tool tray above the filter housing.
Re: Cb550 air filter
« Reply #1 on: May 08, 2021, 03:14:56 PM »
Havent got my parts books to hand so is there a foam filter in bottom air box and a steel tube sticking up, if so the 550 f should fit if not a 500 one should. As to tool tray you may well have to import one from us and may well not get the mesh filter as they are even more rocking horse poo. Julis does the mesh but not the holder
Offline 550turnip
« Reply #2 on: May 08, 2021, 03:40:01 PM »
Here is a pic inside the box, current filter has a hole in the bottom of the metal plate that looks like it locates in a tube, the current filter has cb550f on it so I think it will fit ok
« Last Edit: May 08, 2021, 03:43:26 PM by 550turnip »
« Reply #3 on: May 08, 2021, 05:05:24 PM »
Yes the filter will fit but you are missing a part, i will try and look at it on cms for you
Edit, you are missing part number 17350374003
« Last Edit: May 08, 2021, 05:12:53 PM by Bryanj »
Offline 550turnip
« Reply #4 on: May 08, 2021, 05:51:39 PM »
I will get the air/oil seperator  when onecomes available, I have ordered the air filter.
Thanks for your help
Offline Seabeowner
« Reply #5 on: May 08, 2021, 07:15:27 PM »
Also p/n 17350404670 is basically the same part with a different length protruding tube and fitted to the 550K3. Maybe in an attempt reduce oiling of the air filter by the recirc system.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline 550turnip
« Reply #6 on: May 08, 2021, 11:00:24 PM »
Thanks for all the help, looks my airbox was stripped of parts at some point, I can never understand why people do this...the result is usually a decree in performance and rough running
