Author Topic: worn advance/retard unit?  (Read 3576 times)
Offline billdn
« on: May 16, 2021, 02:12:57 PM »
Still having troubles setting the damn timing , see earlier post, so thought I'd have a good check on everything - the advance/retard unit has what looks to be some wear around the base -I say wear because it looks uneven, eg not machined and is worse on the 1-4 side compared to the 2-3 side - could this be why I have hit and miss success when trying to set up static timing with a test light, no matter how much I adjust points gap. Or am I just clutching at straws! Pics of a new one on DS are not clear.
Re: worn advance/retard unit?
« Reply #1 on: May 16, 2021, 02:27:55 PM »
Not surewhat you mean as there is only 1 cam that operates both 1/4 and 2/3
Offline billdn
« Reply #2 on: May 16, 2021, 02:46:20 PM »
Bryan
It's just that the central column seems unevenly worn where the bob weights go in .
« Reply #3 on: May 16, 2021, 06:31:13 PM »
As per Oddjod plus if there is no sideways play between cam and shaft its ok
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #4 on: May 16, 2021, 06:40:00 PM »
What are the actual symptoms when trying static timing? I made a mistake once when I didn’t connect the croc clip properly to just the wire and accidentally grounded it.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #5 on: May 16, 2021, 08:47:15 PM »
If using a bulb it should light just as the F Mark lines up with the static mark
Offline billdn
« Reply #6 on: May 17, 2021, 08:15:34 AM »
Gentlemen - thank you for your advice and reassurance. For some reason I decided to turn the advancer unit through 180 degrees, to be honest I don't recall taking it apart previously but it's been so long I can't remember!
Any way everything went swimmingly with setting timing and test light , turned the key and she started!!! All this time advancer unit was wrong way round -aargh!
So pleased!!!, would put up a video clip but it tells me it's too long to load.
But it does show the value of this group and like minded people.
Alright it smokes like a chimney(assembly oil) and the carbs need balancing but I've built my first ever engine and it works!!
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #7 on: May 17, 2021, 08:41:18 AM »
That's a great result Bill,
No one can take that feeling of elation away from you when the pile of inanimate bits of otherwise scrap metal bursts into life after your own work.  Even after 50 odd years of black fingernails, I still get that same buzz - I think we all do!
Keep up the good work!
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline JezzaPeach
« Reply #8 on: May 17, 2021, 09:18:29 AM »
An easy mistake, great result and just in time for better riding weather!
« Reply #9 on: May 17, 2021, 10:05:17 AM »
It's great when a plan comes together, I can well remember timing my 250 AJS, timing disc, rod down the plug hole. Very precise but it would not work at all, spent ages at it then the light bulb moment came, I had been turning the engine backwards.
« Reply #10 on: May 17, 2021, 11:42:27 AM »
I had a magneto ign Triumph T110 and i once timed it on the lh cyl instead of the rh and it ran like a sick pig, after carefull checking the slip ring in the maghad a 15 deg variation between the sides, took me several hours with a stone to get them within 5 deg
