Author Topic: CB750F1 Sprockets  (Read 4465 times)
Offline Skoti
CB750F1 Sprockets
« on: January 24, 2010, 07:26:56 PM »
Hi,
I want to up the gearing on my F1 but I'm not sure if there's enough space for a larger front gearbox sprocket.
The front sprocket is cheaper and easier to change than the rear sprocket so can anyone advise me if there is enough space to replace the standard 17 tooth front gearbox sprocket with say an 18 tooth sprocket without the chain fouling the sprocket cover mounting lugs etc ?   :)
Skoti
1976 Honda CB750F1
Re: CB750F1 Sprockets
« Reply #1 on: January 25, 2010, 06:13:45 AM »
From memory just ad long as you dont use a super HD or O ring chain
Offline Skoti
« Reply #2 on: January 25, 2010, 08:49:02 AM »
Do you mean a bigger sprocket will fit in OK if I don't use a super HD or 'O' ring chain with it? :-\
Skoti
1976 Honda CB750F1
Offline lordmoonpie
  • If he's not in action, he's in traction...
    • Moonpie
« Reply #3 on: January 25, 2010, 09:04:06 AM »
Yes - there's *just* enough room to go to an 18 tooth sprocket as long as you have a standard non-HD or O/X-ring chain. It's still tight though so you have to keep on top of chain maintenance and tension. Personally I'd go for a change to the back sprocket on the basis of safety...
Beware of those who fall at your feet - they may be reaching for the corner of the rug...
Offline Skoti
« Reply #4 on: January 25, 2010, 01:11:13 PM »
Hi,
thanks for your help, will probably take your advice and change the rear sprocket  :)
Skoti
1976 Honda CB750F1
