Author Topic: F1 rear wheel alignment  (Read 2501 times)
Offline pamsman
« on: May 23, 2021, 11:38:54 AM »
Hi I'm in the process of renovating my 1977 CB750 F1, after having wheels rebuilt I tried to fit the rear wheel although it slots into the swing arm and I can get the axle bolt in ok the disc is just rubbing the inner side of the caliper and the wheel is out of alignment favouring the N/S . I have checked all spacers are seated correctly and also replaced the wheel bearings just in case the previous owner ( a bit of a bodger) had fitted the wrong bearings but I couldn't see anything wrong.
Has anyone else come across this problem as I'm completely baffled I just can't work out what is wrong.
Re: F1 rear wheel alignment
« Reply #1 on: May 23, 2021, 11:41:39 AM »
Are the bearings fully seated ?
Just had a look and there was a recent question about the same thing
http://www.sohc.co.uk/index.php/topic,24763.msg225965.html#msg225965
« Last Edit: May 23, 2021, 11:55:16 AM by Spitfire »
Offline pamsman
« Reply #2 on: May 23, 2021, 11:57:34 AM »
I've check the old bearings and they were seated so I replaced with new and made sure they were seated correctly but still the same problem.
I'm almost tempted to take a couple of mm of the top hat spacer but that would be a last resort!
« Reply #3 on: May 24, 2021, 12:10:46 AM »
The bearing behind the locking ring will almost certainly be the culprit. Remove the locking ring and tap the bearing home (ONLY on the outside race!) and you will notice a change in the sound when you hit it and it's fully home. And Do Not machine anything of the spacer, it will not solve the issue!
Sent from my JNY-LX1 using Tapatalk
« Last Edit: May 24, 2021, 12:12:27 AM by hairygit »
Offline pamsman
« Reply #4 on: May 24, 2021, 06:18:59 PM »
Thanks for the input, I will try and knock the bearing a little harder to see if solves the problem.
I won't try to bodge it, sheer desperation set in for a moment.
I can't get back on it until next week but will let you know if I can resolve the problem.
Offline pamsman
« Reply #5 on: June 12, 2021, 08:06:44 PM »
I thought I would give an update on my rear wheel alignment issue. A big whack with a bigger hammer thankfully solved the problem just as you chaps thought. I must be getting limp wristed in my old age.
« Reply #6 on: June 12, 2021, 08:11:19 PM »
Nice one, it's a great feeling to get something like that sorted, pleased for you
