Author Topic: Decals  (Read 4139 times)
Offline allankelly1
Decals
« on: May 24, 2021, 07:22:59 PM »
Hi all
Hope you are all well
Just finishing off my tank and side panel refurb
Now got a question please
Got tank and side panel decals to do next once I am 100% happy with the paint job and wondered for the tank decals do you lacquer the tank decals locally or lacquer the whole tank
Also I guess the side panels are fully lacquered due to the small size
Any advice welcome and many thanks in advance
Best wishes Al
Re: Decals
« Reply #1 on: May 25, 2021, 12:36:48 AM »
On mine I lacquered the whole tank and side panels in petrol resistant lacquer.
Re: Decals
« Reply #2 on: May 25, 2021, 07:40:42 AM »
You need to lacquer the whole tank or it will stand out like a sore thumb  ;)
Offline Orcade-Ian
    • Older Vehicle Web
Re: Decals
« Reply #3 on: May 25, 2021, 09:15:49 AM »
I always 'Scotch' the whole tank lightly, then apply the decals and follow that with a good 2 pack petrol resistant UV stable lacquer.  Best have a word with the local body shop who will be happy do it or just advise.  If you don't key the surface, you run the real risk of peeling later.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline allankelly1
Re: Decals
« Reply #4 on: May 25, 2021, 10:38:44 AM »
Hi all thanks for the advise
Ok I think I will lightly scotch the side panels and do the decals and clear coat on these  first then move onto tank
Again many thanks to all
Best wishes Al
Offline element137
Re: Decals
« Reply #5 on: May 25, 2021, 02:11:44 PM »
Slightly off topic - what front fork/front/brake set - up are you running on that ?
Offline allankelly1
Decals
« Reply #6 on: May 25, 2021, 05:50:50 PM »
Hi
Forks discs and calipers are off a cb400n super dream but with 50mm removed from the stanchions as standard cb400n are too long
Also hub is an original CB400F hub so I can run a standard spoked wheel but the discs are drilled and spaces added to fit the super dream discs
Lastly running a super dream  speedo drive but fitted the CB400F hub with a custom speedo drive as with this change speedo drive is in. The opposite side
Happy to share more details if you are looking at this mod
Best wishes Al
« Last Edit: May 25, 2021, 07:52:53 PM by allankelly1 »
Offline allankelly1
Re: Decals
« Reply #7 on: May 25, 2021, 07:28:24 PM »
The brake lines look nice, who made those up?
Also the headlight bracket look good as well, someone on here looking for a decent set so some details on those would be good. They look well made.
Hi
Brake lines are Venhill
The headland bracket was from eBay
And the horn set up is pure RD350LC with a custom printed horn cover
Best wishes Al
Offline allankelly1
Decals
« Reply #8 on: May 25, 2021, 08:03:00 PM »
Lovely chubley
Hope tank look as good
Before lacquer
After lacquer
« Last Edit: May 25, 2021, 08:10:10 PM by allankelly1 »
Re: Decals
« Reply #9 on: May 25, 2021, 11:21:05 PM »
Looks great Allan
