Author Topic: I think I have a problem with one of the conrods - HELP  (Read 5854 times)
Online McCabe-Thiele (Ted)
« on: June 02, 2021, 10:29:59 AM »
This morning I fitted the two crank case halves and it all went well - all torqued up fitted the primary gear shaft etc.
After fitting the shaft in the primary drive all went together ok.
I held up the timing chain and rotated the crank all seemed okay - I checked the conrods for free movement and number two just seems a bit tight occasionaly compared to the other three that would flick left & right as I expected.
I added some extra oil it seemed to help but at the top of its travel I can feel (or imagine) a slight tight spot.
With the conrod at the bottom of its stroke the rod will move easily to the left & right if you get my meaning - not quite the case when its near the top of its travel?
When I plastigauged the conrods the clearance were the same on all four rods - with each rotation of the crank the issue seems to have improved.
Do I need to seperate the case again & examine number 2 con rod bearings ?
« Last Edit: June 02, 2021, 11:12:27 AM by Macabethiele (Ted) »
Re: I think I have a problem with one of the conrods - HELP
« Reply #1 on: June 02, 2021, 03:30:46 PM »
Did you rotate the con rods on the crank before you fitted the crant Ted to test for any tight spots?
Offline 400 Cafe Racer
« Reply #2 on: June 02, 2021, 05:16:54 PM »
Hi Ted,
As a matter of interest, what readings did you get with your Plastigauge on the Con rods and the Main bearings.
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #3 on: June 02, 2021, 07:58:35 PM »
No I didn't - clearly I should have done.
« Reply #4 on: June 02, 2021, 08:06:31 PM »
Hi Ted,
All four were 0.0010 thou or 25 microns. All four fitted with Green shells.
 Ted
« Reply #5 on: June 02, 2021, 08:09:48 PM »
I'm thinking as I have not gone any further I will have to split the crankcase to see if there are any bearing marks - not looking forward to removing the Honda bond.
« Reply #6 on: June 02, 2021, 08:15:23 PM »
When you had the engine apart originally Ted, did you torque up the con rods to see if there was any tight spots which may indicate ovaling of the con rod big ends. If the shells are now marked in any way, it usually means the con rod needs re claiming due to ovaling.
« Reply #7 on: June 02, 2021, 08:37:43 PM »
Hi Ted,
I found that using a small paint brush dipped into a shallow cup of cellulose thinners, then gently brushed over the Hondabond joint face and left for 5 minutes, will soften it dramatically, sufficient to wipe off with a cloth.
Do you know what big end shell colour was installed previously ?
« Reply #8 on: June 02, 2021, 08:59:10 PM »
Hi Ted,
Only one and four had the original Geen markings still visible. The shell codes were all the same but that is probably meaningless. Conrod 2 & 4 were marked 1B  conrod 1 & 3 were marked 1A. The Green shell code was still visible on conrods1 & 4.
I will try some thinners when I dismantle. I should have checked the rotation before I fastened it up.
« Last Edit: June 02, 2021, 09:01:02 PM by Macabethiele (Ted) »
« Reply #9 on: June 03, 2021, 12:11:42 AM »
I will look at that when I take the crank out - I'm just annoyed at myself for not checking - good new its only cost a small amount of Hondabond & my time. I might have to ask you about how to check for ovaling!
« Reply #10 on: June 03, 2021, 07:30:04 AM »
At least you caught it early Ted. If the engine had been fully built up and in the frame that would have been soul destroying.
As you say it has only cost a bit of Hondabond (and it goes off in the tube anyway so at least you are getting VFM!) and time. The bright side is you will know your way around the engine and it's all part of the learning process.
Good luck finding the problem and I'm enjoying the posts.
« Reply #11 on: June 03, 2021, 07:58:14 AM »
Must admit to never finding an oval rod on a Honda motorcyle and not sure it could be recyified due to the tight tolerances Honda work to.
Also never seen a measurably oval pin but everything is older now so anything is possible.
Check back of shell and inside of rod eye is clean and dry
« Reply #12 on: June 03, 2021, 08:41:14 AM »
Strange that something can be felt in rotation, and a bit puzzling.
The only "oddity" there is the oil supply hole but the shells should run clear of it for the oil to get round the centre groove. It's the only thing that could immediately be seen in the context of crank pin up or down in orientation I can think of. Wondering if there's anything snaggy on those shells for that rod.
« Reply #13 on: June 03, 2021, 09:08:27 AM »
Seen hundreds of oval Honda rods in my time. I measure up rods on a con rod reclaiming machine as, it has a dial on it.
Do you have all the rods on the correct way ?
It is always good practice to put the shells in the crank case, fit the crank without the rods, torque up and rotate by hand. And see if any shells are marked. Take the crank out and do the same with the rods on the crank. Checking while building is the best way to go  ;)
« Last Edit: June 03, 2021, 09:52:35 AM by Trigger »
« Reply #14 on: June 03, 2021, 11:24:01 AM »
Hi Trigger - yes the rods are all in the rightway round - as well as my original markings & photos this tallied with the bearing shell notches facing the exhuast side of the engine. It might be a coincidence but when I purchased the shells from Ziggy he only had 7 half bearings - all in sealed Honda NOS packets. I bought one Green shell from DS they had a different batch number  that might be a factor.
I'm even thinking could a dog hair have got in on assembly.
When I split the crankcase later today I will look for any marks on No 2 big end for an idea as to what is wrong.
