Author Topic: Chain lube  (Read 1728 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Chain lube
« on: June 08, 2021, 08:01:43 PM »
Prompted by suggestions in florence’s post I can highly recommend Castrol “Chain Lube Racing” or similar products.
I’m not sure if it has wax or lithium but once dried it doesn’t fling off as easily as oil and doesn’t seem to attract as much build up of deposits, particularly in my road bike gears.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline fogrider
Re: Chain lube
« Reply #1 on: June 08, 2021, 08:14:32 PM »
It's a good tip to apply chain lube straight after a ride, while the chain is warm. It lets it run into the links easier. Next ride it has fully dried on and less likely to fling.
Bought some cheap chain lube once and this was the only way I could use it.
Re: Chain lube
« Reply #2 on: June 08, 2021, 09:13:06 PM »
I second the Castrol chain wax, great product and doesn't fling.
I always apply a quick squirt directly after getting home and before the bike goes back into the garage. The Castrol wax never drips onto the floor once applied.
Re: Chain lube
« Reply #3 on: June 08, 2021, 11:33:02 PM »
I just ordered some, as I want something that doesn’t get chucked all over my new Z1A. Thanks for the info.
Offline JezzaPeach
Re: Chain lube
« Reply #4 on: June 09, 2021, 10:56:22 AM »
Good tip on doing after a ride. Many thanks.
Offline JParty
Re: Chain lube
« Reply #5 on: June 09, 2021, 11:28:33 AM »
Just bought some - thanks for the tip!
Re: Chain lube
« Reply #6 on: June 09, 2021, 02:18:17 PM »
About 20 plus years ago I remember buying a tin off melting chain grease, heat up soak chain and hang up to cool, as far as I can remember that is the only lube on the chain still. But to be fair although I have run the Matchless every year it is only a few dry runs annually. Cant remember what the stuff was called but it was recommended at that time. Now I have WD40 chain wax which seems to be fine. Big difference of course if your running every day all year round, which I am not.
« Last Edit: June 09, 2021, 02:20:00 PM by Johnny4428 »
Offline JezzaPeach
Re: Chain lube
« Reply #7 on: June 09, 2021, 03:37:14 PM »
We were admiring a Matchless G11 a visitor rode to Brooklands a few weeks ago. Same family for about 67 years, purring engine never apart, says something about quality!
Re: Chain lube
« Reply #8 on: June 09, 2021, 03:50:30 PM »
Linklife I think it was called, great stuff for mucking up your Mother's gas hob when you pulled the chain slowly out of the bubbling, moulton can and the end of it would flick around like a snakes tail dripping everywhere!
Re: Chain lube
« Reply #9 on: June 09, 2021, 04:30:10 PM »
Have used this a couple of times. Now no more.
Offline florence
Re: Chain lube
« Reply #10 on: June 09, 2021, 08:40:45 PM »
Those of you that know me will realise I won't be able to stop myself from saying, Scottoiler at this point.  I have one on my 500 and it is simply brilliant.
Mine is placed where the air filter used to be so you can't even see it.
(Replacing the air filter with individual filters is a controversial subject but set up correctly and with non-standard exhaust, bigger main jets, mine runs great.)
