Author Topic: Source of quality top end gasket kit for CB550F in Europe  (Read 5333 times)
Offline alexdecker
« on: June 10, 2021, 09:38:34 AM »
Hey
Just tried fixing a top end oil leak in my CB550F with a gasket kit from eBay. It still leaks oil though, which makes me believe that the gasket kit was not very good. Can anyone recommend a supplier of high quality gasket kits in Europe? Thank you!
- Alex
Offline Tonyh
Re: Source of quality top end gasket kit for CB550F in Europe
« Reply #1 on: June 10, 2021, 09:46:17 AM »
Hi Alex, Try CMSL (Honda spares Netherlands) they can be a bit on the expensive side or David Silver Spares, UK.
Tony.
Offline alexdecker
« Reply #2 on: June 10, 2021, 10:02:03 AM »
Thank for the reply Tony!
I am a little in doubt of these work for the 550F models - can anyone give a quick look and let me know?
https://www.cmsnl.com/products/gasket-kit-ab-topbottom_06112390000p/
https://www.davidsilverspares.co.uk/CB550F2-SUPER-SPORT-1977/part_62279/
Thank for the help!
- Alex
« Reply #3 on: June 10, 2021, 10:37:13 AM »
What make of gasket kit did you use?
« Reply #4 on: June 11, 2021, 02:21:35 AM »
All 550 use thesame gaskets but more important where is your leak from as there are a couple of known leak points thathave nothing to do with gaskets
Offline alexdecker
« Reply #5 on: July 27, 2021, 09:38:11 AM »
I ended up using a Vesrah complete kit for the 550F, and that solved all my problems. Must've been a faulty kit or faulty installation with the old kit :)
Thanks for the help!
« Reply #6 on: July 27, 2021, 09:58:17 AM »
ALL newer gasket kits need thicker O rings at the oil feed through head gasket as the new asbestos free head gaskets are thicker, also a common leak is where the brackets the cam cover end caps bolt to are held to the head, there is supposed to be a soft alloy washer between bracket and head
Offline alexdecker
« Reply #7 on: August 19, 2021, 06:59:39 PM »
Yeah so me Vesrah kit didn't hold up for long before the leak returned. Do you know of any kit that has thicker O-rings, taking the thicker head gaskets into account?
- Alex
« Reply #8 on: August 19, 2021, 08:26:26 PM »
Nope, just get thicker O rings
« Reply #9 on: August 20, 2021, 07:26:06 AM »
Decades ago a Dutch Honda mechanic, specialized in old CBs told me he used Kawasaki O-rings for this that are slightly thicker. I don't know which however.
