Author Topic: Black smoke and hanging idle after a full rebuild  (Read 23844 times)
Offline thomaspigeon
« on: June 15, 2021, 12:51:02 AM »
Hello everyone,
So I’m encountering some issues that starts to be beyond my league. I’m still quite inexperienced and this my very first full project. I’ll try to be as thorough as possible into my set up and problems as I know you’ll ask me a lot of questions if not  ;D ;D
Symptoms
- black smoke when accelerating
- Erratic idle (I have to play with the screw all the time to get it right)I can manage to keep it steady
- Low revs sputter and strong engine brake feeling
- mid/high revs quite ok but struggle to come back down
- engine run rougher when hot
Now about the bike
Model : CB550K3
Intake : Pods K&N (I bought this bike as an unfinished project and the air box was discarded already unfortunately!)
Exhaust : 4 into 2 with a short muffler
Carbs : 069A
Main jet : 110
Idle jet : 42
Needle : aftermarket (I’ve lost one OEM so can’t fit them but if anyone got a spare 273004 I’m happy to buy it)
Needle height : 3rd from top
Float height : 23mm
Mixing screw : 1.1/2 turns was looking like the best one
Top engine rebuilt with new pistons and rings, new valve seal, valves have been lapped
Ignition
I made a DIY LifePo4 battery that seems to run ok (though no BMS on it)
Electronic ignition from David Silver
Spark advanced system with the springs a bit retighened to make sure it comes back down.
Coils : https://www.ebay.co.uk/itm/112789241229
Spark plug caps : NGK 5K ohm
Spark plugs : NGK D7EA
Sliders don’t seem to stick and it looks like they are coming back down ok. I’ve set up the slide heights with a drill bit, the synchroniser was looking ok even though the pressure is very low. Spark plugs are very sooty but dry.
It’s a full rebuild with a lot of mods so I believe it might take me some time to get there but your help would be very appreciated. Let me know what you guys think!
Tom
Re: Black smoke and hanging idle after a full rebuild
« Reply #1 on: June 15, 2021, 01:01:34 AM »
I forgot to mention, I tried to run it with a standard idle jet and the needle a bit higher but none of this helped, it actually was worst. Also the symptoms were quite the same.
What is hard to understand for me is how I have such a soot which means running rich while my idle is hanging which mean lean?
« Reply #2 on: June 15, 2021, 08:23:43 AM »
Think you're quite close with assessment of mixture, black smoke being unburnt fuel in excess of what's needed.
As you say though,  slightly mixed message with hanging idle.
http://www.sohc.co.uk/index.php/topic,17769.0.html have you completed the first stage of method to sync in link? It's that bit that can easily get the throttle mechanism "hanging" slightly if not done accurately and would be my first call to examine.
The pattern needles are giving some very odd results in general site response and would be ideal to get that last one to remove that variable if at all possible.  In the meantime,  you could try setting them at top clip position (needle lowest) to get further assessment.
Offline fogrider
« Reply #3 on: June 15, 2021, 09:23:52 AM »
I suggest you replace the main jet O rings. Even if it's just to eliminate that as a possible problem, it's cheap enough to try. You want 1.2 section by 4.2mm ID. That size is available. The lightest smear of petroleum jelly will help them push in. Don't twist them !!
Make sure they go on the end with the shortest end boss. (it's the deepest location for the O ring.).
« Reply #4 on: June 15, 2021, 01:44:37 PM »
Hey guys,
Thanks for you answers. @fogrider, the main jets are new with new o-rings so should be ok on that side.
@k2-k6 I haven’t done this method for syncing the carbs so will get through it probably this week end. Now dropping the needle might be a solution. So far the mixing screw doesn’t seem to do much. I remember with the stock 38 idle jet it was already doing the hanging idle and black smoke.
Also I’m wondering if the electronic ignition can fail at all. I could almost ride that way at some point but it wouldn’t be enjoyable as too erratic. It kind of misfire now as I think the plugs are getting too sooty.
« Reply #5 on: June 15, 2021, 02:22:21 PM »
All K3s are prone to a hanging idle. The black smoke is intriguing however. Often it is a reduced air intake.
« Reply #6 on: June 15, 2021, 03:17:37 PM »
If its a Dyna ignition the US board reports a lot of faiures
« Reply #7 on: June 15, 2021, 05:24:15 PM »
I stopped reading at Pods K&N. They have got to go on a K3 the carbs don't like them at all. Search the internet for a correct airbox.
« Reply #8 on: June 15, 2021, 05:47:06 PM »
But... his are 069A carbs...
« Reply #9 on: June 15, 2021, 05:55:14 PM »
Ah yes missed that sorry. So he's running F carbs on a K bike? They work better with pods but that said the internet is full of people trying to get a stable setup with pods fitted. I would still get rid of them and remove a known complication.
Offline fogrider
« Reply #10 on: June 15, 2021, 06:17:17 PM »
Re the main jet O rings, I also installed new main jets that came fitted with new O rings. I was'nt  totally satisfied they were sealing fully , when removed and measured, they were 1x4 ( nominal) and , since O rings are sometimes subject to shrinkage in  manufacture, they were actually 0.9mm x4, which is a tenuous fit.
I figured 80p for 4 'O' rings was worth the effort.
« Reply #11 on: June 15, 2021, 06:42:40 PM »
Interesting comment about strong engine braking. Not sure if you have had a rebore or how many miles you have covered since the build but I personally would not be altering too much until the engine has at least partially run in.
« Reply #12 on: June 15, 2021, 07:23:03 PM »
Shutting the throttle with it running that rich will give alot of engine braking as it's probably close to stalling like that.
« Reply #13 on: June 15, 2021, 08:18:29 PM »
@bryanj here are the electronic ignition that I’m running (not a Dyna S) https://www.davidsilverspares.co.uk/CB550K3/part_192275/
I still have the points somewhere so I might give it a go.
I probably have some O rings kicking around so I can change those
I can’t try anything until this week end but yes definitely a hanging idle and black smoke is a mixed message. Now I’ve read somewhere that you can solve this by dropping the needles so can be worth the try.
Also I know it’s a complication but I can’t put the air box back as the previous owner discarded the air box
« Reply #14 on: June 15, 2021, 08:23:45 PM »
I mean he removed the brackets on the frame
