Author Topic: tightened or not  (Read 2345 times)
Offline smoothoperator
tightened or not
« on: July 09, 2021, 05:20:43 PM »
Rebuilding my engine and I'm looking for a way to mark nuts etc that have been tightened, too many paint pens to choose from, but can anyone recommend one or some alternative?
Steve
2017 Triumph Bonneville T100
Offline ST1100
Re: tightened or not
« Reply #1 on: July 11, 2021, 03:24:51 PM »
oil pastel chalk or whiteboard marker come to mind... both are non permanent...
(omnipresent on Japanese made kits I'm working with/installing  8) )
STOC #637
« Reply #2 on: July 11, 2021, 03:57:36 PM »
Yellow Tyre chalk.
« Reply #3 on: July 11, 2021, 07:00:02 PM »
I use Humbrol model paint and a paintbrush.
Offline 4wDaz
« Reply #4 on: July 11, 2021, 07:18:56 PM »
Genuine And Aftermarket Motorcycle Parts Supplier
« Reply #5 on: July 12, 2021, 09:14:34 AM »
Thanks for the replies. I'll give the ebay pens a go.
Steve
« Reply #6 on: July 12, 2021, 07:14:08 PM »
When I was racing, after a scrutineer pointed out, to my horror, that my upper shock mounts were finger tight, I adopted a policy that I still use today - either properly tighten everything in case it gets forgotten, or make it obvious that something isn’t tight by just starting the thread.
« Reply #7 on: July 13, 2021, 07:54:54 AM »
Putting fasteners on finger tight to be secured later is a very dangerous policy that will always lead to loose bolts etc. Whatever your working on either leave it off completely or tighten everything before you leave it. This is the advantage of having an MOT (even for the exempt bikes) after a rebuild, another set of eyes to check it's all done correctly.
