Author Topic: Gearbox selector forks - do they look right  (Read 2973 times)
« on: July 12, 2021, 12:16:13 PM »
Last night whilst trying to nod off I started to worry about having put the middle selector fork in the right way around as I start my rebuild.
This is not helped by trying to rotate images in my head when a picture is taken from the front of the engine casing - classic overthinking!
I could not find a photo from when I stripped it down but did check it against a photo I had of Nurse Julie's 400 rebuild that looks the same.
My manuals do not seem to show it clearly - the Honda Manual on sohc is great for the left & right selector but the centre one is not that clear.
Can someone please confirm I have them in the correct position....?
gear selectors pic 1 by Macabe Thiele, on Flickr
Offline 4wDaz
Re: Gearbox selector forks - do they look right
« Reply #1 on: July 12, 2021, 12:56:32 PM »
Genuine And Aftermarket Motorcycle Parts Supplier
Offline TrickyMicky
« Reply #2 on: July 12, 2021, 01:10:23 PM »
Never dug that deep into the 'works' yet, but saw this on Fleabay if it's any use mate.
« Reply #3 on: July 12, 2021, 01:17:13 PM »
You only have to drop the shafts with gears on into the casing to find out
« Reply #4 on: July 12, 2021, 03:13:43 PM »
So if it's the wrong way around the gears will not fit.
That's okay as they fit quite easily!
Looking at it again if it was the other way around the fork would sit all wrong - I'm overthinking & worrying since having to strip back for the stripped bolt fiasco.
« Last Edit: July 12, 2021, 03:27:00 PM by Macabethiele (Ted) »
« Reply #5 on: July 12, 2021, 06:12:55 PM »
If it was the wrong way round the peg would not locate in the selector drum track
You are correct of course its obvious when you say it our loud. In my head I was thinking the slight offset would be on the wrong side but in fact it just would not fit.
