Author Topic: CB500 Frame differences U.S. vs UK  (Read 4262 times)
Offline Scotty67
« on: July 22, 2021, 08:55:27 PM »
Hi there. Apologies in advance if this question has been asked already, I did a search on 'frames' and a lot came back :D.
Anyone  know of any frame differences between a UK bike registered 01 Jun 1972 and U.S. frames 1971-176?
Thanks,
Scott
Re: CB500 Frame differences U.S. vs UK
« Reply #1 on: July 22, 2021, 09:23:34 PM »
The UK and USA  500 frames are the same and the 500 frame was also used on the USA 550K0, K1 and K2 as far as i am aware  ;)
Offline Scotty67
« Reply #2 on: July 22, 2021, 10:56:41 PM »
Fantastic, thank you!
Offline Scotty67
« Reply #3 on: July 22, 2021, 10:58:22 PM »
PS. The 500 I bought came with a spare 550 engine. I assume that will bolt in OK? Cheers Scott
« Reply #4 on: July 22, 2021, 11:14:28 PM »
It will fit but, the rear engine bracket is different on the 550 and don't expect anymore power as both engines are rated at 50 BHP  :o
« Reply #5 on: July 23, 2021, 06:40:23 AM »
Does a 550 motor produce more torque? I seem to recall all the mags at the time lauding the 550 as a significant riding improvement over the 500 motor? Maybe just the usual journal hype. I’ve never ridden either, though hope to have mine on the road this year.
Offline Scotty67
« Reply #6 on: July 23, 2021, 07:08:28 AM »
Thanks Trigger!
« Reply #7 on: July 23, 2021, 08:08:53 AM »
Gearbox, gearchange and clutch operation were biggest changesplus crabkcases casting had slight difference so primary chain does not hit oil gallery quite as much
