Author Topic: Primary drive bearings do they wear less than the chain itself ?  (Read 4064 times)
I have a new primary drive chain - regarding the two primary drive shaft bearings is there a proper way of checking them for wear ?
I cleaned mine in petrol - lubricated them gave them a spin so in the absence of any poor rotation,  noise or general movement etc decided they are ok.
The bearing cage makes it almost impossible to see any pitting or anything.
I've priced the bearings at a fair price @ £14.30 at DS do folk here replace them if funds allow  ?
Re: Primary drive bearings do they wear less than the chain itself ?
« Reply #1 on: July 23, 2021, 11:03:19 PM »
I would if it were me Ted, I would have to say 'why not'. The bearings will have a number on them, have a look on ebay or other bearing suppliers and you will get them a lot cheaper than DS.
Make sure the bearings are a good make, NTN, KOYO etc.
« Last Edit: July 23, 2021, 11:21:43 PM by Nurse Julie »
« Reply #2 on: July 24, 2021, 09:13:04 AM »
Thanks for that NJ.
Offline 4wDaz
« Reply #3 on: July 24, 2021, 09:48:54 AM »
Ds use NTN, does it say 6205 on it Ted ?
Genuine And Aftermarket Motorcycle Parts Supplier
« Reply #4 on: July 24, 2021, 09:53:40 AM »
Yes it's marked as JAPAN   DY  NTN 6205.
Looking at bearing suppliers they list several bearings under the same number as per this link with 13 & 15 mm thickness.
https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords=ntn%206205&
« Last Edit: July 24, 2021, 10:00:16 AM by Macabethiele (Ted) »
Offline 4wDaz
« Reply #5 on: July 24, 2021, 10:04:02 AM »
Are they 13mm or 15 mm ? My wholesaler list them instock but the 15 mm are alot cheaper
« Reply #6 on: July 24, 2021, 10:12:24 AM »
My calipers say 15 mm width.
« Last Edit: July 24, 2021, 10:14:43 AM by Macabethiele (Ted) »
Offline 4wDaz
« Reply #7 on: July 24, 2021, 10:15:36 AM »
I'll price a pair up and pm you if you want ?
« Reply #8 on: July 24, 2021, 10:22:46 AM »
That would be good if it's not too much trouble I've sent an enquiry to a Derby firm by e-mail.
My worry is the type descriptions such as Open Type (that fine) Deep Groove ??
Offline 4wDaz
« Reply #9 on: July 24, 2021, 10:36:54 AM »
Open type means they are not shielded at the sides that’s all, Pm sent
« Reply #10 on: July 24, 2021, 11:13:16 AM »
6205 should all be the same outer, inner and width
Offline 4wDaz
« Reply #11 on: July 24, 2021, 11:43:39 AM »
Yeah thats what i thought but if you look at the link for simply bearings it quotes 2 widths, 13mm and 15mm as does my supplier
« Reply #12 on: July 24, 2021, 12:40:08 PM »
Thanks for the PM & your help. Cheers Ted
Offline 4wDaz
« Reply #13 on: July 24, 2021, 02:57:34 PM »
No problem, parts supply is a big part of my day job so if I can help somebody save a few quid I’m more than happy to help out
