Author Topic: i usually use STP  (Read 5680 times)
Offline captaindonutbikes
i usually use STP
« on: February 12, 2010, 03:20:52 PM »
but anyone got any other recommendations/old wives tales/urban legends for assembly oil?
cheers
cb550k3 cafe
Offline totty
Re: i usually use STP
« Reply #1 on: February 12, 2010, 03:47:41 PM »
I've never used it but several people have recommended a Molyslip assembly oil. I've used their engine and gearbox additives, chain oil and air drying film (ADF - dry anti seize compound).
« Reply #2 on: February 12, 2010, 04:33:15 PM »
I always use prodigious quantities of clean engine oil when assembling.
Offline mick
« Reply #3 on: February 12, 2010, 05:59:21 PM »
I use the same oil i'm going to run the bike on when rebuilding the motor ;), cheers Mick.
« Reply #4 on: February 12, 2010, 06:07:37 PM »
If its going to be run soon after buiding loads oil from the can you will fill it with, if it's gonna stand for a while assembly lube---I use copaslip, turns the oil an odd colour but never had a problem
« Reply #5 on: February 13, 2010, 11:09:33 AM »
Like others I usually use the same engine oil that I'm going to run the bike on.
Den
Offline Yoshi823
  • Biker to the bone...
« Reply #6 on: February 19, 2010, 06:53:43 PM »
I must admit to have heard lots of suggestions about what to use when assembling an engine, but I think that there may well be more than one to use, depending on which area of the engine that is being put together. When I first started to rip engines apart & reassemble them, I always used engine oil. But as I got into bigger more expensive engines like the 750 & 1000 Exup engines, I found that I needed something a bit more substantial. When installing valves into guides for example, engine oil would tend to be wiped off. So I have used Bel-Ray assembly lube (with molylube). This is exactly the same as the Rocol ASP or anti-scuffing paste that I used to use on radio & radar components & it lasted well. But when I used this on my 750 cam bearings, I found that it was a bit too heavy, & the stuff ended up in the sump plate as a gooey mess. So I asked around & ended up using some stuff called Lubriplate #105 white grease from the USA. This I use on cam bearings & followers, big & main bearings.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
