Author Topic: Separating top end from bottom end in one piece?  (Read 13662 times)
Re: Separating top end from bottom end in one piece?
« Reply #30 on: July 29, 2021, 03:58:13 PM »
In respect to the Vesrah kit, did you use the o rings that came with the kit? I’m advised to use a 3mm thick o ring for the cylinder head oil valves rather than the standard 2.5mm item?
« Reply #31 on: July 29, 2021, 08:19:56 PM »
Pm sent Ken
Offline alexdecker
« Reply #32 on: July 30, 2021, 11:32:13 AM »
Yes, I only used sealers and O-rings from the Vesrah kit…
- Alex
« Reply #33 on: July 30, 2021, 11:58:43 AM »
Cheers Alex.
« Reply #34 on: July 31, 2021, 10:55:08 AM »
Hi guys, further to this topic on  o ring sizes for cylinder head oil way seals I’ve measured this morning as I was going to fit cylinder head. The machined recess in the surface of barrels is 1mm and my vesrah gasket is 1.65mm I dont see a 2.5mm o ring being a lot of benefit here. I actualy found a 2.65mm o ring in a set I had but even this is not going to cut it. Am I right in thinking this has going to have to be 3mm thick rings?
« Reply #35 on: July 31, 2021, 11:54:45 AM »
Won’t the gasket get compressed?
« Reply #36 on: July 31, 2021, 12:30:04 PM »
Steve,  i did wonder about that, but how much is a 1.65mm head gasket liable to compress under full torque? I have not a clue.
« Reply #37 on: July 31, 2021, 01:08:51 PM »
Well if it’s compressed from 1.65 to 1.00, then a 2.5 o-ring would be fine.
« Reply #38 on: July 31, 2021, 01:25:48 PM »
Absolutely Steve. This is exactly what I need to know!
Offline alexdecker
« Reply #39 on: September 04, 2021, 05:08:32 PM »
Did you end up on a 2.5 or 3 O-ring?
« Reply #40 on: September 04, 2021, 07:01:52 PM »
I ended up with 2.65mm because that’s all I had. Fingers crossed they do the trick.
Offline alexdecker
« Reply #41 on: January 23, 2022, 01:57:21 PM »
So - following up on this - did the 2.65 o-rings do the trick?  :)
