Author Topic: Generator bolt  (Read 3121 times)
Offline allankelly1
Generator bolt
« on: August 12, 2021, 05:00:02 PM »
Hi just a quick one
Is the generator rotor retaining bolt a left or right handed thread please
And same question please for the clutch retaining nut please
Just saves on a stupid mistake
Many thanks in advance
Best wishes Al
« Last Edit: August 12, 2021, 05:03:11 PM by allankelly1 »
Offline smoothoperator
Re: Generator bolt
« Reply #1 on: August 12, 2021, 05:07:03 PM »
Both are right hand thread but wait for a second opinion! I found loosening the generator bolt is easy with an impact driver.
Steve
2017 Triumph Bonneville T100
Offline allankelly1
Re: Generator bolt
« Reply #2 on: August 12, 2021, 05:27:45 PM »
Thanks all
I can see I will need to spend some time in the machine shop tomorrow making a puller and clutch peg socket
Best wishes Al
Re: Generator bolt
« Reply #3 on: August 12, 2021, 05:27:57 PM »
Is it the rear wheel spindle that can be used to remove the alternator rotor on these?
Offline allankelly1
Re: Generator bolt
« Reply #4 on: August 12, 2021, 05:31:17 PM »
Ohh
If it was that would save me a job as will borrow spindle of the other bike if that is the case and just make a plug to jack against
Best wishes Al
Offline allankelly1
Re: Generator bolt
« Reply #5 on: August 12, 2021, 05:50:40 PM »
Ok
Just checked my rear spindle and it’s M16
Re: Generator bolt
« Reply #6 on: August 12, 2021, 07:50:25 PM »
Dont think the rear wheel is same and you need someting you can beat hard as the rotor is, or should be, on tight
Offline allankelly1
Re: Generator bolt
« Reply #7 on: August 12, 2021, 08:00:18 PM »
Yes they are usually quite tight but tonight found out bolt was just past finger tight and so was the counter shaft pinion retaining bolt too
Not moaning as its a strip down but hopefully the rotor is just snuggly on its taper
Best wishes Al
Offline allankelly1
Generator bolt
« Reply #8 on: August 13, 2021, 05:28:32 PM »
That worked a treat and a nice fit considering I did a guess on the thread depth when thread cutting on the lathe at work
Also made one of these too for the clutch nut
« Last Edit: August 13, 2021, 06:02:18 PM by allankelly1 »
