Author Topic: Head is leaking oil again. Again.  (Read 12597 times)
Offline alexdecker
« on: August 19, 2021, 06:57:52 PM »
Hey all
I installed a new gasket and o-ring set the first time I took the top engine apart on my CB550F2 from 1977 . Sourced it from CMS. The bike still leaked oil. So I sourced a Vesrah complete gasket set and put that in instead. The bike is still leaking oil from the top. I have made sure that all surfaces are clean and even, and I even used some extra sealing silicone the second time around to be sure. And still it leaks. I am running out of ideas as to what to do.
Has anyone else had a stubborn leak, that they finally got rid of somehow?
- Alex
Re: Head is leaking oil again. Again.
« Reply #1 on: August 19, 2021, 07:27:10 PM »
Are you sure its not the end cap O rings that are leaking? they are very, very prone to it.
Offline alexdecker
« Reply #2 on: August 19, 2021, 07:59:40 PM »
I took some photos. It's in each end, but that is the only place the leak is.
Offline alexdecker
« Reply #3 on: August 20, 2021, 11:26:29 AM »
Take a pic of where the leak is and we can advise on the usual suspects, it's too vague saying it just leaks, there are a number of areas prone to leakage and we need to isolate where it's coming from.
Just uploaded two pics. It leaks in each end, making me think maybe its leaking from the o-ring on each side of the engine. But I am not sure if it can be anything else. Any advice is greatly appreciated!
Offline alexdecker
« Reply #4 on: August 20, 2021, 11:27:15 AM »
Just uploaded two pics - one of each side. It seems like its the o-rings that are in each side of the motor. What do you think?
« Reply #5 on: August 20, 2021, 12:26:30 PM »
I can't see a lot from your pictures -It's a long shot but an easy fix - are you sure you have good venting from the top of the engine a bit too much crankcase pressure can push oil out at the easiest places. Sorry if you have checked that.
« Last Edit: August 20, 2021, 12:28:27 PM by Macabethiele (Ted) »
« Reply #6 on: August 20, 2021, 04:09:04 PM »
No expert on the 500/550 engine having only rebuilt one engine but from memory, if the 550 is like the 500, doesn't the (handed) cam cover end cap 'L' brackets (that the end cap screws to) have copper sealing washers on the bolts that are sometimes mistakenly get replaced with ordinary washers? Could it be that?
Offline alexdecker
« Reply #7 on: August 20, 2021, 05:35:39 PM »
It's the oil gallery O-Rings, most likely because aftermarket head gaskets are thicker than Honda ones and they don't appear to make the O-rings they supply thicker to compensate for that, so they crush like they should and end up leaking.
OE gasket will solve it unless there is some damage to the surface but then why both ends at the same time?
Thank you for this advice. Sorry for a potentially stupid question (English not being my first language), but what does OE mean? That the gasket follows the original factory specs? Or?
« Reply #8 on: August 20, 2021, 06:26:49 PM »
Honda gaskets are thicker as well its all due to no asbestos. Two gaskets in that short order i would check head and block for flatness and that correct length dowels between head and block are used
« Reply #9 on: August 20, 2021, 06:34:51 PM »
Same part number Ken
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #10 on: August 21, 2021, 01:46:32 PM »
Either way I wonder if it’s worth trying slightly over sized quality o rings as an additional precaution?
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline paulbaker1954
« Reply #11 on: August 22, 2021, 08:40:27 AM »
I went round the houses trying to fix the same problem and got very frustrated.
As Trig says there is an issue with the thickness difference between aftermarket head gaskets and OE ones.
I finally cured mine by……….
1 Using an OE gasket (DSS can supply)
2 Having the head skimmed to ensure it was flat
Since I did the above no probs at all.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline alexdecker
« Reply #12 on: August 23, 2021, 07:31:13 PM »
I already made sure the head was flat. So an OE set from David Silver or thicker o-rings. Does anyone have a source for usable o-rings. This will be the third time taking the top apart. Would really like to get it right this time!
« Reply #13 on: August 23, 2021, 09:09:22 PM »
Try Nurse Julie on here who stocks a wide range of quality O Rings
« Reply #14 on: August 23, 2021, 10:17:07 PM »
I know posted somewhere are the O ring sizes cos i did it but im at work so cant look in my very old parts book to tell you, then just google an o ring slightly thicker section
