Author Topic: Wiring Harness  (Read 2515 times)
Wiring Harness
« on: August 20, 2021, 08:24:22 AM »
Just a thought on wiring harness regarding repair/replace. I have read different snippets regarding replacement harness’s for different models, problem being to get an exact copy of what was on the bike originally. When I restored the 550k3 I opened up the harness by removing all the tape laid out all the wires and examined cleaned and checked for hardening etc, repaired replaced wires and plugs appropriately then re taped and ended up with a descent harness that I knew was not hiding any skeletons. The thing is I would do the same with the 750 unless there is a good reproduction harness on the market. I know there are several suppliers out there, anybody had any experience with aftermarket harness’s for the 750 in particular?
Offline 71 V12
Re: Wiring Harness
« Reply #1 on: August 20, 2021, 01:50:33 PM »
Reusing an old harness can be problematic whilst occasionally may be necessary as new replacements cannot be bought. Over time water will creep up the copper in the PVC insulation and cause corrosion. The wires become brittle and weak. If you cut and strip an old cable you can see how far up the the insulation the corroded wires go.
I used the DS aftermarket on my K4 and it is fine. I would say the Japanese bullet connectors are not as robust if connected/ disconnected several times, as the OE but they are easily tweaked again to get a solid connection.
Two years on no electrical issues to report.
« Last Edit: August 20, 2021, 02:15:57 PM by 71 V12 »
Re: Wiring Harness
« Reply #2 on: August 20, 2021, 03:16:11 PM »
Do these guys do one for your model they list quite a few for various Honda 550 variants?
https://www.electrexworld.co.uk/acatalog/WH-377.html
« Last Edit: August 20, 2021, 03:18:21 PM by Macabethiele (Ted) »
Re: Wiring Harness
« Reply #3 on: August 20, 2021, 03:38:49 PM »
I have used 3 DS looms on my standard K2, as a base for the CR750 Rep loom and on a k6 - plus 500k2 and they have all been good quality for not a lot of cash (in my opinion)
Re: Wiring Harness
« Reply #4 on: August 20, 2021, 09:37:44 PM »
Thanks guys, just ordered one from DS.
