Author Topic: Sump Oil Strainer unit  (Read 4162 times)
Re: Sump Oil Strainer unit
« Reply #15 on: August 25, 2021, 11:47:42 AM »
Faced with their imminent extinction  :o and if no pattern part emerges to fill the void, can more frequent oil changes be enough to cope with not having one at all?
I  suspect it's needed as all cars have them as well as an oil filter- if you have debris in the gearbox for instance (where engine/gearbox share the same oil) it's going to drop into the sump and get sucked into the pick up so a strainer is essential in my view to keep out large bits of metal or rubber etc.
In the complete absence of a replacement I guess it will be a case of adapting one from another engine and joining it to the same end fitting.
« Reply #16 on: August 25, 2021, 03:21:56 PM »
It has to be there as the hole it fits into snugly is too high upnfor oil to be reliably sucked in
