Author Topic: How is the front three way connector fitted to the frame.  (Read 3499 times)
« on: August 24, 2021, 05:51:42 PM »
Not sure how I attach the 3-way connector that has the front brake lamp switch attached is fixed to the frame - parts book isn't much help if anyone has a photo that would be handy?
My front brakes came in a box aside from the disc & handlebar part.
« Last Edit: August 24, 2021, 06:28:21 PM by Macabethiele (Ted) »
Offline Deano400
Re: How is the front three way connector fitted to the frame.
« Reply #1 on: August 24, 2021, 06:43:35 PM »
Does this help?
Offline smoothoperator
« Reply #2 on: August 24, 2021, 07:48:05 PM »
Here's another one.
Steve
2017 Triumph Bonneville T100
« Reply #3 on: August 24, 2021, 07:51:35 PM »
So it's via a rubber mount on the headlamp/ indicator bracket. Thanks both of you. Ted
Just looked again it fits to that empty thread I have on the bottom yoke !!
« Last Edit: August 24, 2021, 09:29:52 PM by Macabethiele (Ted) »
« Reply #4 on: August 24, 2021, 10:55:09 PM »
No rubber bit just bolts tight to bottom yoke
« Reply #5 on: August 30, 2021, 12:22:03 AM »
Looking at the picture then the headlamp / indicator frame bolts on top of the small bracket attached to the 3-way connector - the steel insert in the rubber mount will hold it firm to the frame.
Offline Deano400
« Reply #6 on: August 30, 2021, 10:43:38 AM »
Yes that's correct.
« Reply #7 on: August 30, 2021, 02:24:17 PM »
Yes that's correct.
Looking at the frame wiring diagram there is a wiring harness Clip at the front of the frame its item 74 in the parts list 32123-375-000 DS no longer available is this held on with the same bolt??
Offline Deano400
« Reply #8 on: August 30, 2021, 02:48:10 PM »
No. The clip you are talking about mounts on the under side of the steering stem between the stem and the right fork leg. If you look on the underside of the steering stem you will see the mounting hole.
« Reply #9 on: August 30, 2021, 03:16:08 PM »
Thanks I hadn't noticed that !
« Reply #10 on: August 30, 2021, 05:10:51 PM »
That would a 500 twin part if you find one to rob used
« Reply #11 on: August 30, 2021, 09:08:12 PM »
My 500-4 has the same clip, no idea why it has a 375 middle number though unless it got superceded, I’m going to be make no some cable clips when I get my Gateros plating kit, if they turn out ok and you still need one Ted I’ll make you one.
Thanks for the offeb rOddjob - if in my box of stuff that came with the bike I do not have one I'll be in touch.
As my rebuild progresses the parts I have left over are starting to make it easier to find stuff but only just.
