Author Topic: Ignition backplate fixing screws  (Read 2971 times)
Offline kenrolli
« on: September 13, 2021, 11:09:31 AM »
Hi all just looking to buy some new screws for the points backplate on my '76 Four, can't seem to find any searching the net so if anyone has some idea of where I can source them I would be very appreciative as the old one are so chewed up I hade to use the 'hammer shock' technique, well it worked but not the ideal situation to be in eh?
Thanks in advance for any help provided, ride on pards!!! 8)
Re: Ignition backplate fixing screws
« Reply #1 on: September 13, 2021, 11:30:15 AM »
Try stainless cap heads,
« Reply #2 on: September 13, 2021, 11:31:11 AM »
CMNSL, or DSS, or Westfield Fastners. There are many others……
« Reply #3 on: September 13, 2021, 12:06:33 PM »
Iswap both those and the points fixing screws for stainless cap heads, dont forget the plain and spring washers
« Reply #4 on: September 13, 2021, 01:58:21 PM »
The manual shows item 296 (3) p/n 93500-0514-0A. Its a M5 x14 screw.
https://www.accu.co.uk/en/socket-button-screws/8149-SSB-M5-14-A2?uk_google_shopping=1&c=3&gclid=CjwKCAjw7fuJBhBdEiwA2lLMYYlUwQouYbG8nUGeVHHL25djpEoArC_M7NSCZTaR-f5g9EUsBGTeZxoC26cQAvD_BwE
Screwfix do M5 x16 pack of 50 in SS for £2.99 just cut 2 mm off!
« Reply #5 on: September 13, 2021, 03:25:52 PM »
Good No Ted, if you fit allen keyed bolts you tend to either shear them off or most often you strip the thread clean out of the backplate, they can exert far too much pressure for such a small screw. Use crosshead screws, they tend to slip and round before you can strip the thread out.
I hold the small end of the Alen key so I'm more likely to puncture my old fingers than shear a thread whilst nipping it up - that said mine are plain screws - I take your point too tempting to overtighten.
Offline wildtapholer
« Reply #6 on: September 13, 2021, 10:06:08 PM »
I've done the same allen bolts, the screws I took out were a nightmare to remove, just a gentle nip between your fingers of the allen key screw is plenty.
Offline kenrolli
« Reply #7 on: September 14, 2021, 08:48:45 AM »
Well thanks to all, was quite overwhelmed to get such a response! At least I know where to come in the future. Thanks again to everyone that took the time to answer my query, cheers guys..... 8)
