Author Topic: 400 Carbs from a Bloke in Hull  (Read 7173 times)
« on: September 15, 2021, 07:40:13 PM »
My mate in Beverley can't get his 400/4 carbs to perform properly (despite U/S cleaning etc. ) and he was away on Holiday so asked me to make an offer on these eBay ones, from a bloke near me in Hull (he had borrowed my Gerben restored ones and the bike ran perfect with my carbs fitted).
https://www.ebay.co.uk/itm/224607055306
I went to pick them up the same day as buying them and it seems the seller is a retired engineer and refurbs them to sell on. Must admit, I am well impressed .. refitted with all Keihin brassware .. all steel parts nickel plated, cleaned up alloy but not too 'blingy' and set-up and tested on his own superbly restored 400/4.
I can pass on his details if anyone is interested .
Re: 400 Carbs from a Bloke in Hull
« Reply #1 on: September 15, 2021, 08:35:27 PM »
Thats cheap
Offline Cookie2050
« Reply #2 on: September 16, 2021, 11:35:15 AM »
Speaking about carbs, what do people think about these carb rebuild kits on E Bay. im sorting mine out at the moment and if they leak when i test them will they be the best soloution
« Reply #3 on: September 16, 2021, 12:38:01 PM »
Which ones, there are many?
Contact Nursejulie of this forum who can supply O-rings, JIS screws etc. Try to retain your original brass if you can.
Offline Athame57
« Reply #4 on: September 16, 2021, 03:44:06 PM »
What I've always wanted to find, to no avail so far, is a source for getting those rubber parts in the carburetor holder set separately. Anyone know?
1978 CB400F2 named Elen.
« Reply #5 on: September 16, 2021, 04:27:40 PM »
As far as iknow they dont exist unless you can make your own
Offline Charlie J
« Reply #6 on: September 16, 2021, 05:02:47 PM »
The rubber parts fell to pieces when refurbishing my carbs. Am I ok to assume it’s ok to run without them?
Charlie
« Reply #7 on: September 16, 2021, 06:35:31 PM »
Charlie
I can't work out what they do aside from making it easier to assemble all four carbs onto the mounting plate.
Offline Athame57
« Reply #8 on: September 16, 2021, 07:11:31 PM »
Almost anything rubber that isn't a seal, electrical or your tyres I'd put down to being for suppressing vibration.
« Reply #9 on: September 16, 2021, 07:34:57 PM »
Dust covers.
« Reply #10 on: September 16, 2021, 08:29:12 PM »
Correct, keeps the secret additive out of the ball joints      alegedley
Offline Athame57
« Reply #11 on: September 16, 2021, 08:54:53 PM »
Dust covers.
So we don't need to panic if they crumble when we dismantle a bank of carbs for renovation?
« Reply #12 on: September 16, 2021, 08:55:29 PM »
I think they are a bargain especially if he keeps the original brassware. Pattern parts can be a nightmare especially the float valves that always seem to leak. I like the level tube, I must try and make one of those, got to be easier than setting the floats with a gauge that can also be a bit hit and miss.
« Reply #13 on: September 16, 2021, 08:59:34 PM »
Dust covers.
No George, no need to panic. The carbs function just fine without them.
Offline Cookie2050
« Reply #14 on: September 17, 2021, 08:58:46 AM »
I will do, got some of Nurse julie's seals in my oil pump :D
